front blocks
Old Jul 1, 2014 | 10:23 PM
brian1080's Avatar
brian1080
front blocks
Anyone seen this? front springs on my 78 f250. The blocks are connected to the springs.
Old Jul 1, 2014 | 10:57 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Fail-fail-fail, they just bolted the block to the springs and used the head and bolt tail as a spring pad pin.
Cut the bolt that holds it to the spring pack (all 2). Put in an Add-a leaf for 1 to 1 1/2 " worth of lift.... or rebuild your front packs all together.
Ditch the blocks, please BAD idea, unsafe, un-stable, truck wreck waiting to happen.
Old Jul 1, 2014 | 11:35 PM
brian1080's Avatar
brian1080
truck is getting parted, springs are getting scrapped. I just thought it was wierd that I couldn't get the blocks off. I figure I'll keep the blocks. I'll post a pic of the rear springs tomorrow. Looks like a homemade conglomoration, broken and rusted leaves everywhere. :P
Old Jul 3, 2014 | 06:18 AM
Bud Mud's Avatar
Bud Mud
who makes an add a leaf for the front of these trucks? Or will any add on leaf work?
Old Jul 3, 2014 | 08:28 AM
77&79F250's Avatar
77&79F250
Jegs sales Skyjackers... Skyjacker Add-A-Leaf Springs - Free Shipping on All Orders @ JEGS
JC Whitney sales Rough country....Rough Country Add-A-Leaf Kits - JCWhitney
Summit.. Pro Comp....http://www.summitracing.com/int/sear...dd-a-leaf-kits
4 Wheel Parts...Skyjacker Part skyflf724 - Front Fitted Add-A-Leaf for Skyjacker Leaf Springs - Fits Ford F250 67-79 - 4 Wheel Parts
Jack it...Front Add-a-Leafs | Jack-It, The Suspension Experts
I got mine years ago from JC Whitney for the front of my all stock 77.5 F250. I am very happy and it gave the 33x12.50x16.5's a little more front fender room. Only 1.5 worth of lift, but that is all I wanted.
Old Jul 3, 2014 | 10:45 AM
Bud Mud's Avatar
Bud Mud
Mines an early 77. thanks
Old Jul 3, 2014 | 10:46 AM
77&79F250's Avatar
77&79F250
Do you have 6 pk or 2 pk front leafs? There will be a length difference in applications, I do believe.
Old Jul 3, 2014 | 10:49 AM
Bud Mud's Avatar
Bud Mud
6 positive arch.
Old Jul 3, 2014 | 11:04 AM
montana_highboy's Avatar
montana_highboy
No one makes a Highboy specific front Add-A-Leaf but some of the generic AAL's can work, or you can pick up a Highboy spring pack from the junkyard and build a "******* pack" to achieve your desired lift.
77&79F250's Avatar
77&79F250
Just thought I would mention it, cause you will probably need a longer center pin. And your spring clamps might not be in the same position.
Also I would order a new u bolt kit...those old dirty rusty road grime packed fine thread u-bolts are usually are a bear to take off.
Also a great time to do a u-bolt flip...https://www.wfoconcepts.com/cr/U-Bolt-Kits/3208/3612
WOW welcome back around MTHB, did you get just paroled or did the jailers get tired of your sense of humor and release you or what? lol JK welcome back. Missed you buddy
Old Jul 3, 2014 | 11:14 AM
Bud Mud's Avatar
Bud Mud
thanks for the info bud. you the man.
hamr56
22
Jan 24, 2018 06:21 PM
BLDTruth
May 25, 2016 04:33 PM
mdbsbl8
Jan 24, 2012 10:58 PM
jdv19
47
Feb 8, 2010 01:29 PM
78f250_rls
Offroad & 4x4
Apr 6, 2008 11:57 PM
