Leaf Spring Help
Old Jan 18, 2012 | 09:38 PM
mdbsbl8's Avatar
mdbsbl8
Leaf Spring Help
Hi I'm currently restoring my dad's 79 f150 4x4 and I just removed the axle and leaf springs. I was hoping if someone could help me identify what kinda of springs they are. From the searching I have done my guess is that they are stock springs with an overload spring and I'm assuming that the block under the springs are used to give the truck a lift. If someone can confirm this or point me in the right direction it would greatly be appreciated.
Old Jan 18, 2012 | 10:00 PM
JB78f150's Avatar
JB78f150
The block is stock but not sure about the helper springs.
Old Jan 21, 2012 | 12:52 AM
mdbsbl8's Avatar
mdbsbl8
Ok cool thanks. I wasn't sure if I had seen those blocks on other trucks. Does anyone have any info on the leaf springs?
Old Jan 21, 2012 | 06:17 AM
FineSeventyNine's Avatar
FineSeventyNine
Tennessee Hillbilly
The helpers are add-on....IIRC factory overload springs are captured under the same U-bolt plate as the stock springs and don't have those u-bolts out on the ends.
Old Jan 24, 2012 | 10:42 PM
mdbsbl8's Avatar
mdbsbl8
I have looked at some more pictures of overload springs and I see what your talking about. Am I wrong to assume that these function simliar to overload springs by providing support. I always thought the truck had a small lift but wasnt sure if it was a lift or the 35" tires. Could the helpers provide a small lift? Anyone else have any more information.
Old Jan 24, 2012 | 10:52 PM
7636074460's Avatar
7636074460
that short spring on the bottom is like a main overload, a lot of people stack those in for lifts but usually just blocks. i doubt those addon helpers would lift it much at all. another lift option is adjustable shackles
Old Jan 24, 2012 | 10:58 PM
Blue and White's Avatar
Blue and White
The aftermarket overloads do help with heavy loads... but really hurt the ride empty or with light loads.
hamr56
22
Jan 24, 2018 06:21 PM
bewford
Feb 14, 2010 09:42 AM
j tate
Jun 13, 2007 08:38 AM
aksniper
Apr 17, 2002 04:27 PM
