trans temps
Old Jun 30, 2014 | 09:17 PM
NBT22555's Avatar
NBT22555
trans temps
Just wondering what peoples trans temps usually run let say on an average day 75 or 80 degrees outside.
Old Jun 30, 2014 | 09:43 PM
jr2000sd's Avatar
jr2000sd
Mine have been at 165-175 and i have two coolers on it. It uesd to be around 140 all day and then it just jumped up for some reason,also just flushed it for synthetic. Im not sure whats going on
Old Jun 30, 2014 | 10:28 PM
KJNDIVER's Avatar
KJNDIVER
up until two weeks ago i would be 160-170 when 80 outside. Now after the new trans and cooler in sig below, i barely crack 150, even with it being 91 today.
Old Jul 1, 2014 | 12:07 AM
1L243's Avatar
1L243
140 to 150 with 6.0 trans cooler..
Old Jul 1, 2014 | 04:38 AM
River19's Avatar
River19
Towing 6000lbs over the weekend in 85 degrees I was 175-190 depending on where I was. Highway was 175-180, side roads 190 or so due to slower speeds etc.
Around town, I'm 140 or os.
Stock cooler, JW Valve Body......
Old Jul 1, 2014 | 06:40 AM
lhud's Avatar
lhud
I run an Edge Engine Monitor and have a 6.0 trans cooler. I monitor IAT, Trans T, Oil T and some other parameters. What I have noticed is that you can take the ambient air temp., IAT (unless it is in the 100's) multiply it by two and that is a good ballpark trans. temp. The oil temp. is then approx. 50 deg. higher than the trans. temp. All of these are based upon the engine being at operating temps and not towing anything.
Of course, if the ambient temp. is extremely hot outside this method may then be off possibly on the high side.
Old Jul 1, 2014 | 02:41 PM
SteveH-CO's Avatar
SteveH-CO
On an 80 degree day, in stop-and-go traffic with a stock trans cooler, towing a 2000# camper - 205F. In more open traffic, it stays at about 190.
Old Jul 1, 2014 | 02:45 PM
Dan V's Avatar
Dan V
90 degrees above ambient.
SoCalAngler
Jan 12, 2018 10:19 PM
joeyd61
23
Mar 21, 2011 07:13 PM
aldridgec
19
Jan 26, 2010 11:36 AM
2cylguy
Jan 13, 2010 03:11 PM
