300 ring type
Old Jun 30, 2014 | 07:25 PM
abranz's Avatar
abranz
300 ring type
What were the oe rings on a 93 4.9, moly faced or cast?
Which type would you put in a 4.9 honed standard bore on a backyard rebuild?
Thanks
Old Jun 30, 2014 | 08:18 PM
redroad's Avatar
redroad
If your honing your cylinder then cast will seat best in that environment ..
A good read
Old Jun 30, 2014 | 08:33 PM
JimsRebel's Avatar
JimsRebel
Thanks
I used cast on my $100 engine in truck overhaul. They will be more likely to break-in in a used bore. I did not even run a hone through it, just rings and rod bearing.
The rings sealed up fine and got rid of my excessive blow by problem. 5 out of 6 top piston rings were broken.
I would use felpro 525SD head gasket an the newer one piece oil pan gasket.
It is kinda freaky ... but it doesn't leak a drop of oil and goes 3500-4000 between oil changes without added any oil, It was using a qt every 800 miles. Best $100 I ever spent on the truck.
Jim
Old Jun 30, 2014 | 11:45 PM
abranz's Avatar
abranz
Thanks appreciate the responses
Old Jul 1, 2014 | 07:07 AM
hillcountryflt's Avatar
hillcountryflt
Jim
How difficult was the oil pan gasket change since you did it "in truck."
Mine leaks along with what I believe to be the rear main. Not delving into the engine any time soon, but interested in what it takes to replace the oil pan gasket.
Old Jul 1, 2014 | 10:35 AM
JimsRebel's Avatar
JimsRebel
I had the head off and just lifted it with the cherry picker about 2-3 inches. Not sure about with the head on, but people have done it.
Jim
Old Jul 1, 2014 | 08:57 PM
79ford matt's Avatar
79ford matt
Pan gasket isnt to bad had to pull radiator, starter, lifted off of the exhaust bolt and front valve cover bolt, but I wouldn't use the valve cover bolt again kinda sketchy. If it has a standard watch the clutch bar that runs from frame to motor and it will give more room if u pull valve cover.
rustoleum82
Apr 22, 2015 07:34 PM
adipose
Apr 27, 2007 04:56 AM
sh3d3vilinme
May 17, 2006 10:53 AM
scounts_iii
Nov 1, 2004 02:28 AM
DT 466Man
Sep 26, 2004 10:32 AM
