78 351W AOD install problems
Old Jul 5, 2014 | 11:45 AM
Ab73ford's Avatar
Ab73ford
what did you have to do to hook your speedo?
looks like Oreill's say the part number for the flex plate is FRA205 so i hope it work.
Old Jul 5, 2014 | 01:07 PM
2020's Avatar
2020
Somebody correct me if I'm wrong but I think all AOD's have the speedo gear on the tail
shaft.
Old Jul 5, 2014 | 05:11 PM
0ldman's Avatar
0ldman
My stock connector for the c4 works fine, but my speedometer is slightly off. I swapped my gear from 2.79 to 3:1 and never did swap the gear in the tranny.
As far as I know the c4, c6, fmx and aod all use the same cable.
Old Jul 10, 2014 | 03:54 PM
Ab73ford's Avatar
Ab73ford
hey old Man
you were 100% right. went to OReilly's and bought the Flex plate you were telling me about and it fit in much better.
(Part Number FRA205 from OReilly's).
For Guys out there trying to do the AOD swap on a 351W. Don't do the same thing i did by use the stock C6 flex plate. The FRA205 flexplate sets in about 1/4". over stock slex plate. The stock starter will still work.
old Man thanks agian
Jaybird51
15
Apr 19, 2020 09:36 AM
travisd
33
May 8, 2018 10:10 AM
1Austin112
Oct 27, 2016 04:25 PM
Mr Mucko
Mar 16, 2011 03:29 PM
corner27
Sep 30, 2010 09:44 AM
