460 manifold questions
Old Jun 29, 2014 | 10:38 AM
jgavac's Avatar
jgavac
Does anyone know what the thread size and pitch is on the EFI 460 manifold A.I.R holes? The large hole in the mani itself, not the threads in the insert.
Thanks
Jameson
Old Jun 29, 2014 | 11:36 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
EFI started in 1988.
Maybe you would get a better answer in the '87-'96 forum?
Old Jun 29, 2014 | 12:11 PM
jgavac's Avatar
jgavac
I call them EFI manifolds as a general term for later model (than the 70's I'm used to) manifolds. They're on a 86 carbureted RV. Just referring to the smog control holes.
Thanks
Jameson
Old Jun 29, 2014 | 12:22 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
They are NOT EFI manifolds, nor anything like them...
EFI manifolds (intake or exhaust) won't fit carburetor heads.
NAPA sells the plugs. #131X6 for a bag of ten.
Here's a link to another post I made.
https://www.ford-trucks.com/forums/1...l#post13573780
Old Jun 29, 2014 | 12:30 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
On re reading your original post... these fit into the threaded bung.
If you want the thread in the manifold itself, I'm sorry I don't have that information.
Old Jun 29, 2014 | 12:35 PM
jgavac's Avatar
jgavac
Yeah I'm trying to go into the manifold itself. I couldn't get the pipes to release from the bungs. If all else fails, I'll try again to get them off.
Thanks for the help
-Jameson
Old Jul 1, 2014 | 11:29 AM
jgavac's Avatar
jgavac
The manifold has 5/8-18 threads, which is 5/8NF.
-Jameson
Old Jul 1, 2014 | 11:35 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Looks like 2P175 at Grainger will get you 10 brass plugs for $20.
PARKER Plug,Brass,Tube,3/8 In.,5/8-18,PK 10 - Flared Tube Fittings - 2P175|639F-6 - Grainger Industrial Supply
Old Jul 1, 2014 | 04:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
390148-S36 .. Connector (connects 9B445 to exhaust manifold) / 3/8" inverted flare x 5/8" straight end.
Pic at right: Look at the last entry in 9B445-6.
68cabby
Jun 7, 2012 01:40 PM
my73f100
Nov 12, 2010 06:55 PM
oldjag
Aug 3, 2007 08:09 PM
Voh
19
Jun 4, 2007 09:45 AM
phatpony
Mar 30, 2005 12:31 PM
