boost and hp numbers
Old Jun 28, 2014 | 12:21 AM
sudsmcduff's Avatar
sudsmcduff
not 100% on my scan gauge but it read 18.5 boost and 334hp when i stabbed it today. in stock mode. ic boots blow off in performance mode. does this sound accurate? i do not know where i should be at with the mods i have. thanks.
Old Jun 28, 2014 | 05:11 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
In stock boost is limited to about 19, so that sounds right.
Those HP numbers are hard to trust. I dont know how accurate they are.
Its also not uncommon for boots to pop off if youre not prepared.
Old Jun 28, 2014 | 10:38 PM
Tugly's Avatar
Tugly
I wouldn't trust the HP numbers from a scan gauge - too much theory at play.
Boots: As I gaze into the crystal blue oval, I see yellow tape in your future. Riffraff Diesel has nice boots (with lower T-bolt clamps and plenum inserts) that won't blow. One time I forgot to tighten the clamp on the Passenger IC tube, and it took 30 PSI before it soiled my underwear.
Old Jun 29, 2014 | 12:10 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I have both riffraff boots and inserts. I recommend both!
Old Jun 29, 2014 | 10:47 AM
sudsmcduff's Avatar
sudsmcduff
thanks for the replies. i only seem to blow off the passenger side ic pipe boots. bought a $170 set from ebay. i guess that was mistake #1.
Old Jun 29, 2014 | 04:14 PM
Tugly's Avatar
Tugly
Yeah... many learn this one the hard way. You got off easy with $170 loss, at least you didn't buy a mystery chip or injectors.
Clay... he's the guy. [LINK]
Oh... and don't do that eBay thing until you've cleared it with the forum.
Tdracer344
Aug 15, 2016 05:31 AM
Blue7.3
Australia Chapter
Feb 11, 2015 01:44 AM
nossliw
43
Jul 15, 2012 12:13 PM
afonda
Jan 30, 2010 10:26 PM
honeyb
Apr 30, 2006 09:00 PM
