Ignition problem
Old Jul 1, 2014 | 04:21 PM
Ja1980460's Avatar
Ja1980460
Ok, this is a wild guess. It's cheap, and not too hard, but like I said it's a total guess(throwing parts at it). Replace the ignition switch. They have been known to give intermittent problems. It's located on top of the steering column, underneath the dash.
I followed the instructions in the book, and it said to take loose the cable that goes to the PRND321 indicator, take the u-bracket loose that holds the column to the dash, let the column drop and then you can see and get to the switch. Make sure to follow the instructions that come with the switch(you can get these switches at most parts stores), they have a little alignment pin that you stick in the switch to hold it in position when you are installing it. Then pull the pin when you are done.
I did it, it's still having the same problem. I'm at a loss.
RadioControlGuy85
Jan 7, 2016 06:08 PM
zzprop
Sep 30, 2015 10:07 AM
Backwoods351
1983 - 2012 Ranger & B-Series
Dec 4, 2014 03:18 PM
RangerSaint
Feb 17, 2012 02:10 AM
redwolfhopw
18
May 20, 2008 08:32 PM
