Help me disable ignition/AT shifter interlock
Old Jun 27, 2014 | 12:05 PM
irhunter's Avatar
irhunter
So, something went wrong with my key/ignition. When I turn the key, it unlocks the steering wheel but I can only shift between park and reverse. I suspect the electrical interlock thing.
This is a yard-only truck. I do not want to fix it. I just want to be able to shift into N and D. I imagine there is a wire somewhere that needs +12v or ground applied so the interlock will let me shift.
Help finding the wire will be appreciated.
Roy
Old Jun 27, 2014 | 01:06 PM
madpogue's Avatar
madpogue
What year truck? AFAIK, that's not an electrical interlock. There's an electrical interlock between the brake pedal and shifter, but the key/shifter interlock is mechanical, if memory serves.
Try this - turn the key to OFF (that's the FIRST click after putting the key in, which unlocks the column, but does not turn on the ignition). Then see what gears you can select. If you can get it into Neutral that way, try starting it in Neutral, and see if it will allow you to shift from there to Reverse and/or Drive.
Old Jun 27, 2014 | 01:26 PM
irhunter's Avatar
irhunter
It's the truck in my signature: 1990.
The only positions I can get into, with any key position, are P and R. I wonder if the ability to shift to R is just sloppiness in the interlock system. I can't imagine a system which would allow you to only shift between P and R!
From under the truck, I can look right at what I think the problem is...it is a mechanical device attached to the shift linkage and it has wire(s) plugged into it.
Roy
Old Jun 27, 2014 | 03:14 PM
subford's Avatar
subford
Do not think that would be your problem.
That is the MLPS or as some call it the NS switch.
It turns on the backup lamps, lets the starter engage and lets the computer know what gear you are in.
Photos:
http://www.idmsvcs.com/2vmod/tranny/...res/index.html
Old Jun 27, 2014 | 03:24 PM
irhunter's Avatar
irhunter
Photos:
http://www.idmsvcs.com/2vmod/tranny/...es/index.html/
Darn. That is sure what it looks like, now that you mention it.
I could not get your pic link to work.
I still think my shifting issue is related to my broken ignition...at least, they happened at exactly the same time. I will look again for a mechanical linkage.
Roy
Old Jun 27, 2014 | 03:26 PM
Truck Guy99's Avatar
Truck Guy99
Try disconnecting the linkage for the shifter. It's by the firewall on the driver side. With somebody holding the brake in the cab, try putting it into gear holding the linkage with a pair of vice grips. This will isolate it and tell you if your trans isn't letting it move or the column is messed up
Old Jun 27, 2014 | 03:51 PM
subford's Avatar
subford
Try it now.
Sorry I had a "/" on the end that made it not work.
Old Jun 27, 2014 | 05:19 PM
tjc transport's Avatar
tjc transport
i ain't rite
the problem is the ignition actuator in the top of the column. it usually breaks in a no strt position. but every once in a while it will also break the shifter lock tab off and this will prevent you from shifting out of park.
the only way to really fix it is to remove the steering wheel, and remove the tab.
you may be ably to wiggle the shifter and get it to break the tab, but i doubt it.
your only other option is to put a floor shifter in and bypass the ignition switch.
Old Jun 27, 2014 | 05:33 PM
madpogue's Avatar
madpogue
And of course, the floor shifter could be the kind that goes into a ZF5....
(just sayin'....)
Old Jun 29, 2014 | 05:44 PM
irhunter's Avatar
irhunter
I don't have brakes either. Ha.
OK, TruckGuy, your suggestion wins. I disconnected the linkage right at the tranny (I did it there, as I found it easier to access than the spot by the firewall), and the tranny shifted perfectly. I was then able to dive around the yard to the extent I wanted. This was all just to get the truck in the correct position for pulling the cab.
Seems obvious now that I have a column-related problem. I have always intended to have my rebuilt truck not use the OEM key, and to delete the locking steering wheel function. It's going to get a 5-speed, and I won't need any column shifter.
Thanks for the help, guys.
Roy
Old Jul 2, 2014 | 01:47 PM
BobKittel's Avatar
BobKittel
Let me add a question to this string. I have a E350 van 1993 automatic. Some weeks ago the shift tube and cover tube broke. I dropped the sterring column and put new parts in. The truck shifts just fine now except that the ignition while going to on will not actuate the starter. Did I unplug something, break something or leave something out? I don't seem to have any extra parts, this time. And a question for IRHunter on his problem. Did the shift tube break or twist within its housing? That was my first symptom before it actually broke all the way.
Old Jul 2, 2014 | 02:15 PM
irhunter's Avatar
irhunter
Hi Bob,
I never got around to pulling my column. Eventually ( 1 to 16 months from now) it will come out and I will figure out how to disable the locking steering wheel system. I can only tell you what it feels like.
It feels like the part the key cylinder fits into broke where it contacts the rod, or whatever it is, that then allows the tranny to shift and the ignition switch to turn to start. The only functions which work: the wheel unlocks and the ignition switch powers up the accessories.
My guess: the tube didn't break or twist.
Roy
fc111
May 27, 2019 02:48 PM
V10man
1997 - 2003 F150
Jun 15, 2015 07:56 PM
rgarrett
1978 - 1996 Big Bronco
Jun 1, 2004 12:51 PM
