steel wool 0000 .... water spots
Old 06-26-2014, 11:25 PM
traxx808's Avatar
traxx808
traxx808 is offline
I know there is no sure fire way but I'm looking for the best method for removing water spots. My windows are in need of some help. It's my 94 flare side. I've heard of steel wool 0000. 2000-3000 grit sand paper. tooth paste. buffer with compound. I was thinking of replacing all my glass with new ones but want to try out some things first before I throw money out the window for new glass. All comments suggestions are appreciated on this issue. Thanks fellas.
Old 06-27-2014, 05:33 AM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
Never use steel wool, that will scratch up the glass. I use CLR(calcium, lime, rust remover) to remove water spots that are stuck hard on glass.
Old 06-27-2014, 08:51 AM
Evan_P's Avatar
Evan_P
Evan_P is offline
From what I have seen, bar keepers friend work great for removing water spots.
Old 06-27-2014, 09:27 AM
Crewcabber's Avatar
Crewcabber
Crewcabber is offline
I have used steel wool and windex. If they are that bad I use a razor blade and windex. If you use a razor blade go slow and keep it FLAT against the glass and even pressure.
Old 06-27-2014, 10:24 AM
Phil Woolfson's Avatar
Phil Woolfson
Phil Woolfson is offline
Eastwood has a couple of different products for mild to deep scratches. By the time you get todeep scratches, however, it can be better just to replace the windshield, especially if you frequently find yourself driving west at dusk. Griot's garage has glass polish, which works great by hand with a micrfiber towel to get rid of light haze / spotting.
LeviD
06-21-2017 09:53 PM
kenneBF250V10
Appearance & Dress-Up
68
05-17-2013 01:02 PM
BigFord74
04-05-2008 09:14 AM
cadriver
1983 - 2012 Ranger & B-Series
05-11-2007 01:11 AM
cow_boy104
07-08-2003 04:13 PM
Quick Reply: steel wool 0000 .... water spots
