Sponsored by: Real Truck
Reset door code - factory code no workie
Old Jun 26, 2014 | 06:50 PM
blueray's Avatar
blueray
As title says - I have the factory code. Both the card and pulled the fusebox cover and matched from the module. However, when I enter it, I get nothing. Doesn't click, unlock, nothing. I've tried to enter it and push the 1/2 button and enter a new code which also does nothing.
When I push the 7/8 9/0 buttons it does lock so obviously the keypad is working and has power. I have also tried erasing any previously set codes and it does nothing.
Any ideas? What could I be doing wrong? I have searched but everything I'm finding is what I'm already doing.
Oh, it's a 2003 F250 extended cab for what that's worth
Thanks!
Old Jun 26, 2014 | 07:45 PM
RigTrash601's Avatar
RigTrash601
Found This:
<TABLE border=0 cellSpacing=0 cellPadding=6 width="100%"><TBODY><TR><TD style="BORDER-BOTTOM: 1px inset; BORDER-LEFT: 1px inset; FONT: 10pt verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; BACKGROUND: rgb(243,246,247); COLOR: rgb(0,0,0); BORDER-TOP: 1px inset; BORDER-RIGHT: 1px inset" class=alt2>Lots of people have this problem and I was one of them. My local dealer, with a straight face, quoted $98 to get the code out of the computer. That made me so mad, I decided to find out how to do it myself and tell as many people as I can how they can do it as well. I'm not a Ford mechanic, but I have a 2004 F-350 and I can tell you how I did it. The RAP module was mounted on the fire wall behind the radio. I suspect the easiest way to read the code is to remove the radio. If you can't get it out, remove thefuse panel located below the steering column. With a bright flashlight look to the right and up behind the radio and you should see at least part of a large white label. It will have a large bar code on it as well as the words "Canada" and "FCC" among other stuff. The factory code is the bold five digit number located to one side. This was not easy to see. I had to reach up under the panel and push a wiring loom out of the way while my wife looked for the number, but it was easily worth $98.
Make sure when pressing the controls on the keyless entry keypad you press the middle of the buttons to ensure good contact with the controls.
Programming Your Own Personal Entry Code
1. Enter the factory-set code (keypad will illuminate when first digit is pressed).
2. Press the 1/2 control within five seconds of step 1.
3. Enter your personal 5-digit code. Enter each digit within five seconds of the previous one.
Your personal code does not replace the factory-set code. You can use either code to unlock your vehicle. Each time you set a new personal code the module will erase the previous one in favor of the new code. The factory-set code can not be erased.
Erasing Your Personal Code or A Prior Owner's Code
1. Enter the factory-set code.
2. Press the 1/2 control within five seconds of step one 1.
3. Press the 7/8 and 9/0 controls at the same time within five seconds of step two.
The system will now only respond to the factory-set code.
Unlocking the Doors
1. Enter either the factory-set code or the personal code (Each digit must be pressed within five seconds of the prior digit). The interior lights will illuminate as soon as the first valid digit is pressed.
2. To unlock all the doors, enter the factory set code or a personal code and press the 3/4 control within five seconds of the drivers door unlocking.
Locking the Doors
1. Press 7/8 and 9/0 controls at the same time. The 5-digit code does not have to be entered to lock the doors.
Deactivating/Activating Auto-lock
1. Enter the five 5-digit code.
2. Press and hold 7/8 control.
3. Press and release 3/4 control while holding 7/8 control.
4. Release 7/8 control.
The horn will chirp once if auto-lock was deactivated or twice if auto-lock was activated.
The horn will chirp once if auto-lock was deactivated or twice if auto-lock was activated.</TD></TR></TBODY></TABLE>
Seems like a lot, hope it helps.
Old Jun 26, 2014 | 08:23 PM
blueray's Avatar
blueray
Thanks - Yeah. I have the code but the steps to reset it don't work. May need to go through the long list of codes to see if I can find one that does work. Not sure why the factory one doesn't!
Old Jun 26, 2014 | 08:31 PM
RigTrash601
I wonder if a wire is loose behind the pad or something? When you get it figured out, write it down and let me know, in case I ever have the same issue!
Old Jul 23, 2014 | 09:03 AM
blueray's Avatar
blueray
Well, I bought keyfobs on ebay thinking maybe they would work since the keypad doesn't. They do - sort of. They will always lock but to unlock, I have to push the lock button repeatedly until the horn honks, then push unlock. I think there's an issue with the receiver for the codes. Is that possible? I assume it's the module under the dash? Can that be replaced?
Thanks
Old Jul 23, 2014 | 10:30 AM
SuperDutyScaler's Avatar
SuperDutyScaler
you have the same one as me, there is a key fob battery inside the door panel. From the factory they are sealed but you can easily pop the gasket and replace the battery. Problem is the battery is special and i found mine on a website that sells batteries for like six bucks a piece, i did this BUT water got into mine like ever one ive ever seen and it still wont work...... so i just use the key fob or the tried and trued method key in the door handle lock
robert_l_ross
Jun 20, 2024 10:16 AM
jnobles06
Aug 25, 2018 04:19 PM
scotterd
Jul 27, 2015 06:43 PM
sarge rmb
Jan 29, 2008 04:30 PM
marrotte
Electrical Systems/Wiring
Aug 5, 2006 03:52 PM
