keypad?
Old Jan 29, 2008 | 10:17 AM
sarge rmb's Avatar
sarge rmb
keypad?
Hey I got the master from the dealer when I got the truck but didnt try it. DUMB. I looked under dash and found that it it the correct number but it just wont unlock doors. Am I doing something wrong or do these keypads often fail? I was a GMC guy before this truck so Im not used to keypad locks. I enter the number but nothing!!! Help! Ps. can I change it myself or have to go to dealer? How much??
Old Jan 29, 2008 | 12:04 PM
Downriver Thunder's Avatar
Downriver Thunder
The dealer should be able to reset it. I would think
Old Jan 29, 2008 | 03:20 PM
sarge rmb's Avatar
sarge rmb
Yep I have an appt. on Friday. TY
Old Jan 29, 2008 | 04:30 PM
Ven32's Avatar
Ven32
Here try this first..
Programming Your Own Personal Entry Code
1. Enter the factory-set code (keypad will illuminate when first digit is pressed).
2. Press the 1/2 control within five seconds of step 1.
3. Enter your personal 5-digit code. Enter each digit within five seconds of the previous one.
Your personal code does not replace the factory-set code. You can use either code to unlock your vehicle. Each time you set a new personal code the module will erase the previous one in favor of the new code. The factory-set code can not be erased.
Erasing Your Personal Code or A Prior Owner's Code
1. Enter the factory-set code.
2. Press the 1/2 control within five seconds of step one 1.
3. Press the 7/8 and 9/0 controls at the same time within five seconds of step two.
The system will now only respond to the factory-set code.
Unlocking the Doors
1. Enter either the factory-set code or the personal code (Each digit must be pressed within five seconds of the prior digit). The interior lights will illuminate as soon as the first valid digit is pressed.
2. To unlock all the doors, enter the factory set code or a personal code and press the 3/4 control within five seconds of the drivers door unlocking.
Locking the Doors
1. Press 7/8 and 9/0 controls at the same time. The 5-digit code does not have to be entered to lock the doors.
Deactivating/Activating Auto-lock
1. Enter the five 5-digit code.
2. Press and hold 7/8 control.
3. Press and release 3/4 control while holding 7/8 control.
4. Release 7/8 control.
The horn will chirp once if auto-lock was deactivated or twice if auto-lock was activated.
