Air getting in somewhere
Old Jun 25, 2014 | 06:43 PM
bigfish6025's Avatar
bigfish6025
I think I have air getting into my fuel system from somewhere and I'm hoping you guys can help me narrow it down. I just had my truck sitting for a couple weeks and while it was in my shop I fixed a leaky fuel return line by replacing my O rings and it took quite a bit of extra torque to tighten up the nut that goes to the top of the injector. But I got it to where it didn't leak and she idled nice and smooth. While I was in there I drained the water seperator. A couple years ago I added a length of fuel line to the bottom of my water separator and a needle valve because sometimes the stock one didn't seat back in properly and it would let air in. Anyway, it idled just fine after those 2 maintenance tasks.
This morning I fire it up, drive 5 miles and stop 10 minutes. Try to start it again and it runs for 30 seconds, sputters and dies. I burped some air out of my fuel filter, got it to run down the street to a relative's place and began looking into it some more.
I can get it to start after holding in the schraeder valve on the fuel filter and burping air, however in order to keep it running I need to burp it every 10 seconds or so--and there's air coming out.
Not sure how much fuel I have in the tank, but feeling is it's low. Sender has never worked well since I've owned it. I'm going to add 5 gal before I get into it again tomorrow.
Any thoughts on the culprit?
Old Jun 25, 2014 | 07:36 PM
Scratcher's Avatar
Scratcher
If your running on low tanks you could be drawing air from a collapsed pick up in the tank. Fill the tanks and don't let it drop below 1/4. I had the same problem until I kept my tanks full and topped off regularly. That might not be the problem but it's an easy way to eliminate one possibility
Old Jun 25, 2014 | 07:51 PM
Macrobb's Avatar
Macrobb
I'd guess your low pressure fuel pump may be at fault; it's got a built-in check-valve, and if that goes, you might see leakdown like that.
No matter what, that's some /bad/ leakdown; usually it takes hours to leak to that point.
One easy solution is to just install a check-valve on the intake side of the fuel filter/separator... It solved my problem entirely.
Old Jun 25, 2014 | 08:24 PM
irhunter's Avatar
irhunter
Problem keeping it running means it is probably not a drain-back-lift-pump issue.
I like the fill-the-tank test. If the problem goes away you have an air leak in the pick-up tube.
Roy
Old Jun 27, 2014 | 05:34 PM
bigfish6025
Solved
Turns out it was low fuel. I love the easy fixes. Thanks for the help!
Old Jun 27, 2014 | 06:30 PM
irhunter's Avatar
irhunter
Well, that's great. But, you probably still have an issue. Unless you always want to run with a pretty full tank, you will want to fix the air leak in the pick-up tube (inside the fuel tank).
Roy
Old Jun 27, 2014 | 07:55 PM
bigfish6025
Yeah, I probably should check that out. I need to replace my front tank already, so once I can find one of those & I go in to replace that I'll look into the rear tank issue too.
Until then there's gonna be a 5gal can full of fuel in the back of the truck
Old Jun 27, 2014 | 10:53 PM
Macs1964F100's Avatar
Macs1964F100
where did you get the check valve and what size does it need to be?
Old Jun 28, 2014 | 12:12 AM
Macrobb's Avatar
Macrobb
I used one of these:
http://www.ebay.com/itm/Snowmobile-Primer-Bulb-1-4-to-5-16-Fuel-Line-NEW-/261319029267?pt=Snowmobile_Parts_Accessories&hash=item3cd7d3f213&vxp=mtrIt's a squeeze bulb which, by it's nature, has to have /two/ check valves inside it.
Plus it provides you a convenient primer, if you, say, drain your filter.
You can also tell if you have air in the line very easily -- if the bulb is squishy, you've got air. If it's hard, you don't... at least, as long as your fuel system is together.
When I got it, I expected to need to use the primer feature quite a bit, but it worked far better than expected, and I've only used it a couple of times(while working on the truck).
mark460
Dec 8, 2016 11:34 AM
bigfish6025
Jan 19, 2016 06:33 AM
gironha
Aug 10, 2015 10:52 PM
WVOPWRD!
Jul 27, 2014 01:20 AM
fireeater91
Jun 15, 2004 06:56 PM
