I have a stock 2013 F350 6.7 auto crew cab short bed with 7500 miles. My turbo seems to flutter sometimes whenever it wants and I can never get it to do it when I want to show someone. Sometimes I've had it do it at 35mph in 3rd gear and I've had it do it at 55mph when I let off the pedal all with empty bed and no trailer. I took it to the dealer and they told me its fine, that's it not like my last truck (2008 f250 6.4) and that I should be concerned if it doesn't flutter. Does this sound correct?
Ok thank you for your time. I just thought it was strange to do it not under a load. My last truck only did it under a load (pulling a Chevy 2500 with a enclosed trailer through a field in a foot of snow).
When it's fluttering do you also hear like a metal snapping sound and do you notice it when it's in regeneration as well if you do what is happening is the exhaust valves on left head are pushing exist gases back there is a tsb to replace the valves but vehicle has to be in regeneration for tsb to apply and flutter is the exhaust pulses pushing back into the turbo which makes turbo flutter sound
No metal snapping sounds that I've noticed. Just what sounds to me as a flutter when I let off the pedal. It did it again last night when I let off the pedal pulling up to a stop sign at 20mph.
This may or may not help, depding on the build date of your truck. The TSB that it supersedes (11-12-14) called for the replacement of the trubo which they did with mine. This one came out late after mine was replaced under TSB 11-12-14. I had a hard time reporducing mine but finially got it to flutter with a FORD Tech in the truck.
6.7L—ENGINE SHUDDER WITH OR WITHOUT TURBO TSB 13-4-3
FLUTTER NOISE DURING STEADY THROTTLE—
900-1400 RPM—BUILT ON OR BEFORE 5/16/2012
FORD:
2011-2012 F-250, F-350, F-450
The article supersedes TSB
11-12-14 to add a NOTE
production fix date and update the Service SOME LIGHT SURGE CONDITIONS (I.E. ENGINE
Procedure. LUGGING) MAY STILL BE PRESENT UNDER
CERTAIN ENGINE LOAD AND DRIVING
ISSUE CONDITIONS AFTER PCM RECALIBRATION. THIS
Some F-Super Duty F-250-450 pickup truck vehicles IS A NORMAL CHARACTERISTIC DUE TO
equipped with a 6.7L diesel engine and built on or CUSTOMER DRIVING HABITS AND INCREASED
before 5/16/2012 may experience an engine THROTTLE INPUT MAY BE REQUIRED IN THESE
shudder with or without turbo flutter noise around SITUATIONS.
900-1400 RPM with steady throttle. The issue may
be more noticeable at high elevation, high ambient
NOTE
temperature and/or when driving up a slight incline. PLEASE ADVISE THE CUSTOMER THAT THIS
The concern is not present during regeneration or VEHICLE IS EQUIPPED WITH AN ADAPTIVE
while using cruise control. Some vehicles that TRANSMISSION SHIFT STRATEGY WHICH
exhibit the concern may set diagnostic trouble code ALLOWS THE VEHICLE’S COMPUTER TO LEARN
(DTC) P0299. THE TRANSMISSION’S UNIQUE PARAMETERS
AND IMPROVE SHIFT QUALITY. WHEN THE
ACTION ADAPTIVE STRATEGY IS RESET, THE
Follow the Service Procedure to diagnose this COMPUTER WILL BEGIN A RE-LEARNING
concern. PROCESS. THIS RE-LEARNING PROCESS MAY
RESULT IN FIRMER THAN NORMAL UPSHIFTS
SERVICE PROCEDURE
AND DOWNSHIFTS FOR SEVERAL DAYS.
1. Check all continuous memory diagnostic trouble
codes (CMDTCs). Are any DTCs present other
WARRANTY STATUS: Eligible Under Provisions Of
than the P0299? New Vehicle Limited
Warranty Coverage And
a. Yes - This article does not apply, refer to
Emissions Warranty
Powertrain Control/Emission Diagnostic
Coverage
(PC/ED) Manual and continue with normal
Warranty/ESP coverage
diagnostics.
limits/policies/prior approvals
b. No - Proceed to Step 2. are not altered by a TSB.
2. Reprogram the powertrain control module limits are determined by the
(PCM) to the latest calibration using IDS identified causal part and
release 83.01 and higher. Calibration files may verified using the OASIS
The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do
the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper
vehicle service. The procedures should not be performed by “do-it-yourselfers”. Do not assume that a condition described affects your car or truck. Contact a
Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine
Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin (TSB) was
current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is available
through Ford Motor Company’s on-line technical resources.
Copyright
ã 2013 Ford Motor Company Online Publication Date April 8, 2013 PAGE 1
TSB 13-4-3 (Continued)
OPERATION DESCRIPTION TIME
130403A 2011-2012 F-Super Duty 0.6 Hr.
Sorry about the bad copy/paste, it was a PDF and they don't like that. Here is the Issue and Service Procedure from the TSB.
ISSUE Some F-Super Duty F-250-450 pickup truck vehicles quipped with a 6.7L diesel engine and built on or before 5/16/2012 may experience an engine
shudder with or without turbo flutter noise around 900-1400 RPM with steady throttle. The issue may be more noticeable at high elevation, high ambient temperature and/or when driving up a slight incline.The concern is not present during regeneration or while using cruise control. Some vehicles that exhibit the concern may set diagnostic trouble code (DTC) P0299. Follow the Service Procedure to diagnose this
SERVICE PROCEDURE 1. Check all continuous memory diagnostic trouble
codes (CMDTCs). Are any DTCs present other than the P0299?
b.No - Proceed to Step 2.
2. Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 83.01 and higher. Calibration files may also be obtained at www.motorcraft.com.
I have had the turbo replaced and that’s when it started doing it , it didn’t flutter at all before with the factory turbo, I got the tsb done and it seamed to help a little but it still does it
