Sponsored by: Real Truck
High Trans Temps
Old Jun 24, 2014 | 03:22 PM
Blueh2o32's Avatar
Blueh2o32
High Trans Temps
Posted on a couple of different boards and still no answer.
I googled my problem and saw ARMY350 on this board had this issue in the past. I have messaged him. If anyone else knows how to get in touch with him please let me know or send him this link.
My problem is that on my 2011 F250, with MiniMax, Full Delete, intake and exhaust, the trans temp gets as high as 230 degrees. I have 85K miles on it and have had the tuner for about 50K. While driving down the freeway with no load my tuner defuels due to 220 degree trans temp. I took it into the dealership and they replace the TFT(transmission fluid temp sensor) and then 3 days later it is 230 degrees. One was sitting in bumper to bumper traffic and the other just driving. I don't race, I just like the tuner to enhance mpg. So I take back to dealership and they have it for over a week, and they cant find any problems with it. They tell me they have checked everything and have been trouble shooting through the engineers at ford. Engineers say nothing is wrong and to release the truck to the owner, me.
I then have transmission flushed and am still having the issue. I have talked to the company that installed the tuner and they have not seen this and I have also talked to other performance shops that I have used in the past. I feel that something is wrong, but don't know where to even start.
Any recommendations, advice or suggestions would be appreciated. Thanks in advance.
Old Jun 24, 2014 | 08:31 PM
Blueh2o32's Avatar
Blueh2o32
Does anyone have any experience with adding an aftermarket transmission cooler?
Old Jun 25, 2014 | 05:34 AM
redford's Avatar
redford
FTE Leadership Emeritus
I'd start with removing the tune and going back to a factory tune.
Old Jun 25, 2014 | 09:55 AM
laurin's Avatar
laurin
I installed an aftermarket transmission cooler as well as the high capacity transmission fluid pan and my transmission never went over 200 degrees. The reason that I did the install is that I had my truck, a 1999.5 F-350 CC, over in Italy and when I would drive up Mt Etna, the islands local volcano it would over heat. Once I made those mods I never had the problem again. I don't know about the newer trucks but I am going to be finding out because my new 2014 F-350 temps exceed 200 degrees regularly. I will be looking at the increased capacity transmission pan first, as tha is the easiest fix.
Old Jun 25, 2014 | 11:03 AM
Blueh2o32's Avatar
Blueh2o32
Thanks All
Grantford
Jun 17, 2019 06:45 PM
Blueh2o32
6.7L Power Stroke Diesel
Jun 27, 2014 07:04 PM
Mike F250
May 21, 2009 01:55 PM
bkuuz1
Aug 23, 2008 03:44 PM
