Upgrading Electrical Wireing
Old Jun 24, 2014 | 02:02 PM
landers0440's Avatar
landers0440
Just wanting to see if anyone out there has upgrading there electrical wiring or fuse panel from the old glass fuses to a new style box. If so what steps did you take to do so? Is there much added benefit to this upgrade?
Old Jun 24, 2014 | 02:15 PM
fmc400's Avatar
fmc400
MSEE
There is no benefit from a functional perspective. The risk and work required to do this outweighs the benefit of it being easier to replace fuses. You should hardly ever be replacing fuses anyway. In most cases, fuses only blow when someone does something stupid. Don't do stupid things, and you'll barely ever touch the fuse panel.
Old Jun 24, 2014 | 02:54 PM
landers0440
Reason I ask is because I'm going to be adding some modern features such as power windows, new power seats, good audio system and a few other electrical things so I thought it may be worth upgrading the fuse panel but I guess you answered my question and I'll just leave it be
Old Jun 24, 2014 | 03:43 PM
Canus's Avatar
Canus
You could do like I did and add another fuse/relay box under the hood for additional circuits. I used one out of an Escort to supply power to my electric fan, headlight upgrade, fog lights, etc.
Old Jun 24, 2014 | 03:51 PM
landers0440
So you just ran your power from the battery to the secondary fuse panel and then out to your accessories from there correct?
Old Jun 24, 2014 | 03:53 PM
crazy96863's Avatar
crazy96863
I agree with C-anus... Add an auxiliary box... You can probably find a new box at NAPA for a few bucks so not sure if going to the J-Y would be worth it.
Old Jun 24, 2014 | 03:54 PM
crazy96863's Avatar
crazy96863
yes or install a relay from the ignition switch so all those accessories only get powered when the key is on.
Old Jun 24, 2014 | 04:02 PM
fmc400's Avatar
fmc400
MSEE
I agree with the other folks; an auxiliary panel is the way to go. Leave the original as-is.
GadgetGuy22
1997 - 2003 F150
Oct 6, 2017 06:59 AM
frdlvr35
Jan 27, 2011 06:32 PM
rudy84
Electrical Systems/Wiring
Feb 13, 2004 11:21 PM
rudy84
Feb 13, 2004 11:25 AM
