Sponsored by: Auxito
Fuse Panel Question
Old Oct 1, 2017 | 05:12 AM
GadgetGuy22's Avatar
GadgetGuy22
Arrow Fuse Panel Question
I have a couple fuses that fit loosely into the interior fuse panel. They fail to complete the circuit sometimes due to their loose connection. Bending the prongs on the fuse has helped some.
Is there anything I can do about that?
Old Oct 1, 2017 | 09:05 AM
alloro's Avatar
alloro
Bend the prongs or replace the fuse box.
Old Oct 1, 2017 | 08:34 PM
steve(ill)'s Avatar
steve(ill)
the fuse obviously has not changed, so the contacts in the box must be damaged or bent. A cheaper way to get around this might be to melt a big drop of solder on each fuse leg so it will wedge into the box contacts ? ......... other than that, your stuck removing and trying to "fix" or replace the box.
Old Oct 6, 2017 | 06:59 AM
GadgetGuy22
THANKS STEVE(ILL)!!
The drop of solder on each fuse leg snugged it right up and was easy to do!
WootDogg
1997 - 2003 F150
15
Sep 27, 2020 04:54 PM
dudewayne
Jan 8, 2016 05:31 PM
1996f3507.3
Apr 16, 2010 07:28 AM
mdacton
Oct 10, 2008 05:10 PM
