engine swap / headers
Old Jul 9, 2003 | 02:15 AM
clean79150's Avatar
clean79150
This is an exhaust question, but it is 73 - 79 specific. I know alot of you have probably made the same swap so maybe someone can offer some advise.
I am swapping out a 300 six for a 351-W. The 351 is almost ready to drop in, just got to get a carb for it, then the next weekend I'm off it'll be in.
Which headers will fit the easiest? long or short tube? and are there any clearance problems that I should look out for?
Old Jul 9, 2003 | 10:02 AM
DS02F250's Avatar
DS02F250
Clean 79 150,
Hard to tell. Your safest bet is to test fit the 351W and check for clearances on steering rod, suspension components, starter, etc. Then research the dimensions on various types of headers( full length, shorties, equal length, block huggers). This way you'd increase the likelihood that the headers would fit and you wouldn't have to send them back, order new ones, hope those fit.... yadda-yadda...
Sorry I don't have a definite, slam-bang answer for you but it's a guesstimate without actually being there and seeing the fitment of the 351W transplant.
Shouldn't be too difficult to resolve though... Good luck!
Daryl
Old Jul 9, 2003 | 02:42 PM
dfisher1's Avatar
dfisher1
Clean,
One of the biggest problems I have had with headers is the tranny cooler lines. Be prepared to either wrap the header or the cooler lines. Starter is next. If you can rig a heat shield it will save you some money over the years.
I've never run shorties on a truck but they seem to be an optimal solution. I run full length headers. I usually have to jack the motor up to sneak them in.
Your best bet is to call a local performance exhaust shop. They will give you your options and what mods maybe required for your specific application.
I am a big fan of Hedman headers.
KingFisher
Old Jul 10, 2003 | 06:44 AM
jpb222's Avatar
jpb222
I did the same swap. I used macs 1 5/8" shorty headers for a mustang, they fit perfectly!
Old Jul 10, 2003 | 09:52 PM
clean79150's Avatar
clean79150
Thanks for the replies guys.
John222, your practically a neighbor, I live in Belle Vernon. I'm sure if you bring that 79 out It'll catch my eye. Nice truck!
Old Jul 10, 2003 | 11:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
It's good when questions are answered that easy!
I see both of you have your email turned on, -Thanks!
You might want to check out the local forums at the end of the forum list.
BlueOvalDrifter88
Mar 19, 2005 11:24 PM
Busted knuckles
Apr 10, 2004 07:58 PM
cjben
Exhaust Systems
Jan 26, 2004 05:55 PM
mbricke0
Dec 6, 2003 10:33 AM
fred_darrel
Feb 6, 2003 11:54 PM
