Junction box part number
Old Jun 24, 2014 | 01:26 AM
The Masked Rider's Avatar
The Masked Rider
I knew you were out there Bill. ;o) nice to have a stock part. I'd wrap those wires together until you can get the stock part. Nice to know they are still available ...
Old Jun 24, 2014 | 11:13 AM
daveengelson's Avatar
daveengelson
Came across instrument cluster that included alt. gauge and was not sure whether to run the circuit using a fused or single junction block? Not an authority on auto electrical circuits but did not feel comfortable w/ many amps running to the instruments and dash in event of a short in the alt. circuit so decided to go with the fused as opposed to single point. Purchased 50 amp fuse at local auto parts.
Old Jun 24, 2014 | 11:49 AM
johnmel59's Avatar
johnmel59
My '65 does not have that wiring configuration. I assume it was utilized based on some type of other configuration of the truck.....???
Where do the cables that are there originate and terminate?
Originally Posted by Bighossman34
I hope somebody can help me here, im looking for the part number of the junction box that is on the passenger side fender well of my 65 f100 truck. It rusted up and fell apart on me yesterday and i cant find one anywhere!
Also can someone tell me what the junction box does exactly. Can it be bypassed?
Old Jun 24, 2014 | 12:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The oil and amp gauges were optional for all models.
Old Jun 24, 2014 | 12:08 PM
johnmel59's Avatar
johnmel59
Great, so I have purchased an Econoline speedometer/gauge cluster with the oil and alt gauges that I plan to install as part of my rebuild.
I'll replace the oil pressure sending unit to work with the oil pressure gauge rather than the light. H
How does the wiring for the alt meter run? I assume there is a wire that will run through the loops on the back of the alt gauge but where does the wire originate and terminate?
Old Jun 24, 2014 | 12:27 PM
NumberDummy
How can you make this cluster work since none of the parts are the same?
Upper pic.
Old Jun 24, 2014 | 12:45 PM
johnmel59's Avatar
johnmel59
Oops, I meant a BRONCO cluster, not econoline -- my mistake
Upper pic.
Old Jun 24, 2014 | 03:06 PM
kestraly's Avatar
kestraly
A link back to this thread, which was also on the same part
https://www.ford-trucks.com/forums/1...-of-these.html
Jmudweiser
15
Jun 4, 2014 08:47 PM
nutinbutford
Jan 3, 2014 10:11 PM
DaveBB
Sep 6, 2013 05:22 PM
threefiftyone
18
Feb 23, 2005 11:39 PM
woppini
Mar 11, 2002 07:26 AM
