Sponsored by: Kumho
lift blocks
Old Jul 9, 2003 | 01:18 AM
Texan1983's Avatar
Texan1983
lift blocks
when i install lift blocks on my 77 f150 does the rear springs have a centering pin? if so, will it still work or is there something i need to buy. i am thinking about a 4 inch lift kit, but not sure how tall the lift blocks will be. also do i need radius arm drop brackets and a drop steering arm?
Old Jul 10, 2003 | 03:13 AM
RRMike's Avatar
RRMike
lift blocks
The block will have a pin in the bottom to go into your spring pad and the top will have a hole for the pin on your spring. RA brackets yes, pitman arm not necessary but recommended.
Old Jul 10, 2003 | 09:39 AM
77'F-150Mudder's Avatar
77'F-150Mudder
lift blocks
With a 4" lift the blocks will probably be 3". You stack them on your stock 3" blocks.
I agree with rrmike to a certain dergree about the piman and RA drops. You could get it in the air without either but it will drive goofy. Another thing I would recomend is swapping the inverted Y steering link setup for the 78'-79' style. No drop pitman combined with the inverted Y setup would make the truck a big handfull to drive.
To lift your truck 4" 100% correctly, you need the 4" drop pitman arm, 3" drop R/A brackets OR extended arms, 4 degree C bushings, 78'-79' steering linkage (pref. w/adj. drag link), and an adjustable trac-bar. You can get away without doing some of these things, but like I mentioned, it will be a handfull.
Old Jul 13, 2003 | 05:13 AM
13hondacr250's Avatar
13hondacr250
lift blocks
Lift blocks are evil things. When my 250 gets its lift there going away. Wheel hop = broken parts = thin wallet = mad wife = sleeping on couch. It all comes around later on.
Tyler
94 F-250 PSD 5 speed
95 F-150 302 5 speed
Old Jul 13, 2003 | 06:20 PM
Texan1983's Avatar
Texan1983
lift blocks
how bad would it handle if i just add 2" lift coils to the front? can i fit 35" tires under that? if i do the 4" lift how much worse would it drive if i do the drop pitman arm and everything else but that steering convertion?
Old Jul 14, 2003 | 03:03 PM
RRMike's Avatar
RRMike
lift blocks
Yes you can fit the 35's fine with 2". It will drive fine with the 2" if you have the 6 degree c-bushings.
Also with the 4" you don't need an adjustable track bar. You can use a drop bracket for the top mount. This will actually give you better geometry than just lengthening the bar if you have a drop pitman arm.
Old Jul 14, 2003 | 05:14 PM
Texan1983's Avatar
Texan1983
lift blocks
another stupid question, where are the c bushings? are those the bushings where the radius arms connect to the front axle? thanks for the help!
Old Jul 14, 2003 | 06:18 PM
RRMike's Avatar
RRMike
lift blocks
Yep, that's them.
