CRAZY BRAKE/ABS ISSUE
Old Jun 22, 2014 | 06:34 PM
02expy's Avatar
02expy
I am having an issue with my 04 EX, about half of the time when coming to stop below 10mph it will make the abs noise and yank the wheel to the right. it will turn 2 full turns on the wheel if you let it...
I went through the brakes looking for a stuck slide pin or frozen caliper with no luck..
I am thinking the problem is with the left front, but with no codes I don't know if I should but a new sensor in it or if I should dig into looking at the toner ring...
any help with this would be great thanks all
Old Jun 23, 2014 | 12:32 AM
superdave02f552's Avatar
superdave02f552
Clean all the sensors see if that helps sounds like the abs is seeing different wheel speeds down low and is freaking out. I have an explorer that did this cleaned it up and forgot about it
Old Jun 23, 2014 | 01:16 AM
ExxWhy's Avatar
ExxWhy
I recently had a similar problem and it was a dirty ABS sensor on the front.
Old Jun 24, 2014 | 10:43 AM
02expy's Avatar
02expy
Cool thanks for the info. I will clean up the sensors and go from there.
Is brake cleaner ok for this or just wipe them off?
Old Jun 24, 2014 | 11:21 AM
superdave02f552
Either or will be fine I brake clean everything
Bluef2.5.0
May 28, 2019 05:17 PM
7700Rob
1997 - 2003 F150
Nov 13, 2007 06:52 AM
mdpitt
1997 - 2003 F150
Oct 13, 2007 10:26 AM
IronMiner
1997 - 2003 F150
Apr 21, 2006 11:36 AM
