Smoking
Old Jun 23, 2014 | 10:01 PM
78fordman's Avatar
78fordman
The vac line will only be a problem with the climate control and the auto hubs. The climate control will default to defrost and the front hubs will not engage or disengage without vacuum. Think of them like a ball point pen, one shot of vac and off will turn them on and to release another shot of vac and they will release.
Old Jun 24, 2014 | 02:09 AM
BigAlsPSD's Avatar
BigAlsPSD
Originally Posted by tcjhkbjt
I posted two pics in the earlier post. One of the looks to be on the fender well on the passenger side, and the other is on the passenger side by the ICP
Your pics are of the vacuum pump and the heater bypass valve. Loosing vacuum shouldn't cause any issues to your engine running, it would just default the vents to defrost and cause issues with the vacuum hub autolocks if you are 4WD.
Old Jun 24, 2014 | 08:26 AM
tcjhkbjt's Avatar
tcjhkbjt
could that be the reason when I turn on my AC it seems like the defrost is on for just a second before the AC comes through the vents like it should?
Old Jun 24, 2014 | 08:28 AM
tcjhkbjt's Avatar
tcjhkbjt
when I did the check on the FICM I got
47.7 at key on and then I got 47.8 while cranking and while the motor was running. Is it safe to say the FICM is ok so that I can concentrate on something different like the EGR and cooler.
Old Jun 24, 2014 | 12:26 PM
78fordman's Avatar
78fordman
The ficm is most likely ok with that voltage.
Old Jun 24, 2014 | 12:34 PM
tcjhkbjt's Avatar
tcjhkbjt
what should I check next?
Old Jun 29, 2014 | 06:23 PM
tcjhkbjt's Avatar
tcjhkbjt
Any idea on what I should look at next,
Old Jul 6, 2014 | 08:32 PM
tcjhkbjt's Avatar
tcjhkbjt
I changed out the EGR valve and drove it around, it really didn't smoke as much but it did smoke some after warming up. What about the ICP and pigtail?
Old Jul 6, 2014 | 08:59 PM
daddykitty's Avatar
daddykitty
pull the down pipe off the back of the turbo to see if you have oil buildup
Old Jul 6, 2014 | 09:21 PM
tcjhkbjt's Avatar
tcjhkbjt
Ok I'll try that, what if I do?
Old Jul 6, 2014 | 11:00 PM
78fordman's Avatar
78fordman
That usually means you need a new Oil seal for your turbo.
Sent from my leash using IB AutoGroup
Old Jul 6, 2014 | 11:18 PM
04badford's Avatar
04badford
I have an 04 f250 with the 6.0 and have about 191,000 miles. The last couple of days I have noticed alot of white smoke and at times black smoke. Also seems like lack of power off the line. Could it be bad injectors ( I have never replaced them since ive owned the truck at
50,000 miles.) No major repairs have had to be done to the truck yet. Im sure it is about to catch up with me though. I did resolder the point on the FICM, could that be the issue again?
Do you hear the Turbo spool up if you have a gauge you could monitor VGT EGR, MAP, baro, EBP this would give some kind of result on turbo, I'm thinking stuck turbo vanes
the ICP ( Injection control pressure ) if oil is out the back side ( connection side) would mean bad sensor you could monitor ICP and ICPV (volts) those two are a little more prone to stall buck surge, and low pressure
Old Jul 17, 2014 | 09:36 AM
  #28
tcjhkbjt's Avatar
tcjhkbjt
pulled the connector off the ICP and there is no oil anywhere, so I'm assuming the ICP is ok. So now on to the turbo downpipe, if there is oil then I need to get a oil seal kit. Also I pulled the EBP tube and it was clear.
Old Jul 17, 2014 | 10:39 AM
  #29
mustang_309's Avatar
mustang_309
Being an 04' you can remove the EGR throttle plate, it is located where the air enters the intake manifold, there is a butterfly valve inside the throttle body that can be removed. If the EGR throttle plate actuator is not functioning properly it can cause problems. Its not really needed and will eliminate that as a possible cause. Only remove the plate from inside and leave the throttle body in place and plugged in, scroll through this PDF and it will show you the location of the throttle plate, https://www.ford-trucks.com/ford-man...ble%20Book.pdf
Old Jul 20, 2014 | 06:25 PM
  #30
tcjhkbjt's Avatar
tcjhkbjt
I took the down pipe off at the cat and it was dry inside, except for a little soot. I couldn't take it off at the turbo due to a I metal piece that was holding the two together at he turbo.
