Mild 460 build
Old Jun 20, 2014 | 08:51 PM
86f150lariat's Avatar
86f150lariat
Mild 460 build
With the 460 I'm putting in my halfton I would like to spice it up a bit. I've decided on a Weiand Stealth intake but the cam choice is still up for grabs. I've been looking into Lunati and am very impressed and a friend suggested a comp ***** thumpr. Anyone deal with any lunati or that thumper? Thanks!
Old Jun 20, 2014 | 09:13 PM
82F100SWB's Avatar
82F100SWB
I personally really like the comp extreme 4x4 grinds, they build very good power down low to get a big heavy truck moving. My 460 has an X4 256/262, .514 lift, performer rpm, headers, porting, 750 edelbrock on top and is 9.5:1.
According to engine analyzer it should be around 430 horse, 500 tq, but the real story is the torque curve, over 400 by 2000 and peak is at 4500. HP peak is 5500. I actually had real head flow numbers to put in, so the computer estimate should be pretty close.
I do not have a lumpy idle, but I can drift a truck on 44's in 4x4 while bouncing off the rev limiter... LOL
460 Horsepower Chart (revised 1/24/09) - 460 Ford Forum
The hp chart is always a good idea to base a build.
Looking at the specs of the ***** thumpr, it is not a cam I would want to run.
Old Jun 20, 2014 | 09:18 PM
86f150lariat
Mines a 2wd is that strictly 4x4?
Diesel_Brad's Avatar
Diesel_Brad
What kind of HP are you looking for? A pretty stock 460 will run Really good in a light half ton depending on the year of the engine
Old Jun 20, 2014 | 09:23 PM
86f150lariat
I believe it's late 70's. Mainly street and county roads but can still cut through the pasture.
Old Jun 20, 2014 | 09:34 PM
RL250's Avatar
RL250
Lunati is pretty good. I have one in my 400, one of thier HE cams. Great for torque.
Old Jun 20, 2014 | 09:40 PM
86f150lariat
What series? I've heard good of their Voodoo series
Old Jun 20, 2014 | 10:43 PM
82F100SWB's Avatar
82F100SWB
No, it is not a 4x4 only cam, they are designed to build big off idle torque and big torque throughout the rpm range while still building good vacuum.
Throttle response with my particular build is nothing short of amazing, especially considering I am horribly mis-geared and am turning 44's with 4.10's.
Old Jun 20, 2014 | 11:09 PM
86f150lariat
I noticed it said most computer controlled vehicles. Mines carbed.
Old Jun 21, 2014 | 07:32 AM
Franklin2's Avatar
Franklin2
Those thumper cams are made for their sound. If that is a priority for you, then run one of them, but like the others said it's not ideal for the max pulling power for your engine.
Old Jun 21, 2014 | 08:31 AM
CountryBumkin's Avatar
CountryBumkin
If you already have the Weiand, no problem - it's a nice piece. But even better is the Torquer II. Also, regarding cam choices, have a custom grind done. Why buy a universal fit cam when you can have a custom ground cam for about the same money. Go to this site 460 Ford Forum - and post about your build, or go to Scotty's site Re in"Car"nation High Performance - Home and/or other professional engine builder and let them spec the proper cam.
They will get all your info (intended use, truck weight gearing, compression, etc.) and get you the proper cam.
PS. Any duration over 226 degrees (at .050" lift) is going to be too much. IMO.
Old Jun 21, 2014 | 08:44 AM
Gary Lewis's Avatar
Gary Lewis
As has been said, the thump comes at a cost. In this case the exhaust valve opens when there is still significant pressure in the cylinder, thereby creating a thump. But, that's wasted power.
Also, be wary of the Weiand intakes. Apparently they have just shifted their production to China and I may have gotten one of the first for a 400 and it is unusable as it has a flange in the front that covers one of the thermostat housing bolt holes. I don't know if all the manifolds have that problem or that production of all of them has been sent to China. But watch out as things appear to have got to pot.
Old Jun 21, 2014 | 09:09 AM
CountryBumkin
For OP information, that Comp Cam is 210 Int., 218 Exh. duration (at .050" lift). A good choice.
Old Jun 21, 2014 | 12:21 PM
86f150lariat
It won't allow me on either site for some reason. And I'm not sure if I need a custom cam
Old Jun 21, 2014 | 12:32 PM
Franklin2's Avatar
Franklin2
I don't agree with that Torquer II intake choice. Those type manifolds look like they are single plane, not a good choice for low end power.
