Sponsored by: Auxito
2000 f150 5.4 throwing code p0358
Old Jun 20, 2014 | 01:30 PM
ghostsd's Avatar
ghostsd
my f150s service engine light came on while towing a loaded trailer.i got home and started trouble shooting since it threw code for #8.i swapped out coil pack with #6 and still same code.i swapped out the spark plug as well,still same code.i tested to see if it was firing to the fuel injector and that was fine.i put a injector additive to tank and used seafoam through throttle body,still same thing.im wondering if i should swap out injector,if it still happens whats the possible issue?any help would be nice.thank you
Old Jun 20, 2014 | 05:43 PM
projectSHO89's Avatar
projectSHO89
You have an ELECTRICAL fault with the #8 coil. There is no need to be screwing with the other stuff.
Check the #8 COP connector. Verify that VPWR is present at the #8 COP connector. Check the wiring harness for the #8 COP back to the PCM, checking any and all connectors for corrosion or physical damage. Check the #8 COP line for shorts to VPWR or ground. If all that checks out, your PCM has probably failed internally.
Old Jun 20, 2014 | 09:16 PM
ghostsd's Avatar
ghostsd
thank you projectsho89,thats what it was.i replaned the coilpack plug and everythings fine.one of the wires broke
johngeorge
15
Dec 26, 2025 05:25 PM
Rob's 04
2004 - 2008 F150
Jun 8, 2015 08:46 PM
roy13
Modular V8 (4.6L, 5.4L)
Oct 29, 2011 04:52 PM
daveh.usher
1997 - 2003 F150
Jul 24, 2010 08:42 AM
kenbob80
1997 - 2003 F150
Nov 25, 2007 06:34 PM
