Sponsored by: Auxito
code p0303
Old Nov 25, 2007 | 02:14 PM
kenbob80's Avatar
kenbob80
code p0303
i changed plugs 1000 miles ago on a 2000 f-150 4/4 5.4 eng at 95,000 miles. what a job. it ran great until it started missing yeserday. i pulled a p0303 code , #3 cylinder misfire. could it be a cop or injector ? i really don't want to tear it apart without some idea. help!
Old Nov 25, 2007 | 05:18 PM
Bluegrass 7's Avatar
Bluegrass 7
Cylinder 3 is easy to work on.
Pull it apart and inspect the plug, and the boot for a defect. Moisture in the well?
If none found, either a coil or an injector is plugged.
That's all you have to work with.
Old Nov 25, 2007 | 06:34 PM
ncranchero's Avatar
ncranchero
Swap the #3 and #1 coil & boot and see if the code changes to P0301. (As mentioned above, look for moisture while doing this.) If so, it's the coil/boot and not the plug. If it stays 303 check the plug, then maybe the injector.
