Strange transmission issue
Old Jun 22, 2014 | 06:17 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Originally Posted by Mark Kovalsky
I have never seen a transmission with an air pocket. I maintain that with the pressures inside a transmission that isn't possible.
What do you suppose was the cause for no forward gearing (after swapping in a new solenoid/valve and fluid) then all of a sudden it was fine?
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jun 22, 2014 | 08:00 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by DZL JIM
The Direct drive solenoid influences the shifts for 3rd, 4th, and 5th gear, I believe is what he's saying.
Maybe he was, but if it was what he was saying he's wrong.
The TorqShift really has six gears. For the most part fourth isn't used and the trans shifts 1-2-3-5-6.
The direct solenoid is used for the 3-5 shift. It holds, but does nothing else for the 5-6 shift. It is not used in 1, 2, 3, or 4.
So I got on it just a little bit last night and the flair to 3rd was better, so I got on it just a little more and it flairs into 4 and 5 as well.
The 2-3 shift is performed by the overdrive and intermediate clutches. The overdrive solenoid releases the overdrive clutch as the intermediate solenoid applies the intermediate clutch. The direct solenoid is snoozing during this shift.
so I am really wondering if it's a tuning thing now for some reason.
I'm wondering that, too. This transmission is so difficult to tune that I always suspect the tunes when I see an issue like this.
I'm stumped.
Old Jun 23, 2014 | 11:14 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Mark,
Thanks for the input.
Van is running VERY well now. Haven't done a thing other than drive it.
Nice firm shifts, and right when it's supposed to shift, even under a pretty good acceleration.
But... With my foot to the floor it won't shift past 55 mph (whatever gear that is, I can't count fast enough). Just revved like it popped out of gear. Took several seconds to find a gear and then on I went.
Even after that it's shifting fine with normal driving.
All part of the adaptive learning strategy?
Whatever it is I'll keep an eye on the filters and just plan on a rebuild as soon as I can. I know that gray sludge wasn't good.
Thanks for the description of the 5R110 shifting, it's starting to make sense how the thing works.
Why is 4th gear not used (for the most part?)
And is the "6th gear" just the torque converter locking? (as in you count one of the shifts when the tc locks earlier in the shifting.) ??
__________________
Old Jun 23, 2014 | 03:06 PM
Mark Kovalsky
No, that's not normal. It's hurt.
The TorqShift is really two transmissions in one case. The front trans is a two speed and the rear is a three speed. Three times two gives six gears. By the way the ratios worked out 4th gear is 1.09:1 and 5th gear is 1:1. Those two ratios are too close to ever be used together. It is always one or the other. When the trans is colder than 0F it shifts 1-2-3-4-6. Above 0F it shoift 1-2-3-5-6.
No, 6th gear is a separate gear ratio. I didn't cover the torque converter locking at all. That can happen in 5th or 6th gears.
The whole sequence is usually 1-2-3-5-6-lock. If you pay really close attention you should be able to feel 5 shifts including the torque converter lock.
Old Jun 23, 2014 | 07:43 PM
MisterCMK's Avatar
MisterCMK
Doesn't it use 4th on some down shifts?
Sent from my Telegraph using IB AutoGroup
Old Jun 24, 2014 | 05:55 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Thank you Mark, great response.
__________________
Old Jun 24, 2014 | 06:29 AM
Mark Kovalsky
Yes it does.
If you are too fast to kickdown to 3rd gear there is a small window of speed where a kickdown will shift to 4th instead of 5th. This will give more torque to the wheels. From 4th it can only shift to 6th or 3rd.
Old Jun 24, 2014 | 08:20 PM
Misky6.0's Avatar
Misky6.0
Wow. Great info Mark. Thanks!
Sent from my Sprint PC36100 using IB AutoGroup
Old Jun 25, 2014 | 10:48 PM
levi'sford's Avatar
levi'sford
Curious to know what you find. Mine did the same thing on. 3/4 throttle acceleration. RPMs up and down, felt like it couldn't find a gear. My 04' and 06' both had the flare.
Rumble phish
2004 - 2008 F150
Dec 9, 2018 07:13 PM
bobaloo11
Oct 30, 2011 01:16 PM
fxdx94
1997 - 2003 F150
Apr 8, 2007 09:36 PM
79oneton
Sep 29, 2003 06:28 AM
Davesull
Aerostar
Aug 8, 2003 05:15 PM
