Hood Struts?
Old Jun 18, 2014 | 10:14 PM
robert_l_ross's Avatar
robert_l_ross
Hood Struts?
The other day I opened up the hood to add some washer fluid and...wow, it was all heavy like!
Thinking the heat has finally killed my hood struts. Anyone replace them? Tips on how to make the swap easy?
Old Jun 18, 2014 | 10:34 PM
VQT's Avatar
VQT
I think "sammie0126" changed her hood struts a few months back. Can find her post about the subject though.
I assume you will need a very good big/long stick to hold the hood up while doing this. You do not want to have the hood coming down on you when the stick didn't get a good stand to hold the hood up.
Old Jun 18, 2014 | 10:57 PM
superdave02f552's Avatar
superdave02f552
Hood prop and a flat screw driver. Pop the little c clips off each end if you look closely you will see where to put the screw driver in the notch opposite of the pivot pop them out. Put screw driver between pivot and Stuart apply a little force and it will pop off. To install simply push the new ones on the pivot and your Rollin
Old Jun 18, 2014 | 11:11 PM
superdave02f552
Now I have not the first clue as to why that randomly said Stuart in the middle of the paragraph
Old Jun 19, 2014 | 12:01 AM
robert_l_ross
I know how to change the struts themselves (did the rear hatch struts)...just looking for tips to safely do it on the hood.
Old Jun 19, 2014 | 12:29 AM
Kdr358's Avatar
Kdr358
Cut a piece of 2x4 to length and use it like an old style prop rod.
Old Jun 19, 2014 | 06:47 AM
jspence105's Avatar
jspence105
I used vice grips on the old strut when I replaced the new one. it takes about 5 minutes I did it in a parking lot.
Old Jun 19, 2014 | 11:07 AM
Apocalypse's Avatar
Apocalypse
This!!!!!!!!!!!!
Old Jun 19, 2014 | 12:53 PM
robert_l_ross
How did you keep the hood up when you pulled the strut to replace it?
Old Jun 20, 2014 | 01:40 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Broomstick, 2x4, appropriately sized child... you get the picture
Old Jun 20, 2014 | 02:37 PM
Mr. Crab's Avatar
Mr. Crab
I did laugh out loud!
Old Jun 20, 2014 | 07:18 PM
FLO98's Avatar
FLO98
I had to do my hood struts right after I bought the truck this winter. It was fine the day I bought it and for about a week after, then the temps dropped way down into the single digits and I nearly lost some fingers when the hood dropped. All I did was have the new ones ready to go and swapped out one side at a time with some help from my 5 year old and my pregnant wife, worked out just fine! Not too challenging over all just need some kind of prop stick or a pregnant wife with assistance from a 5 year old
Old Jun 20, 2014 | 07:22 PM
Stewart_H's Avatar
Stewart_H
It's not even spelled correctly!
Stewart
Old Jun 20, 2014 | 09:51 PM
jspence105's Avatar
jspence105
I used a piece of cardboard from the box and used it to protect the shaft of the new one and used vice grips again.
Old Jun 21, 2014 | 02:17 PM
housedad's Avatar
housedad
Never mess atound with having old struts. They can kill ya.
https://www.ford-trucks.com/forums/1...-reminder.html
