05 6.0l intake question
Old Jun 18, 2014 | 07:35 PM
Jnm2359's Avatar
Jnm2359
Having problem finding donut gasket for intake on 6.0l. Ford says not serviceable without purchasing a new intake. Any information on where to get this donut gasket would greatly be appreciated. thanks in advance
Old Jun 18, 2014 | 07:44 PM
jswartz84's Avatar
jswartz84
Runs-wifey had the part number not long ago, shoot her a pm.
Old Jun 18, 2014 | 07:57 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Copy/Paste of her post:
05-05-2014, 11:55 AM
Runs-wifey
Intake Donut Gasket: Solved
Maybe I have been driving myself for nothing the last couple of days... Looking for just the Intake Donut gasket... I pulled our huge overhaul kit off the shelf , found the baggie with the International Part number and called my local International Dealer... ( 1836551C1 )
ELEVEN IN STOCK !!!! For under $10
So I don't need to spend the 80-110 bucks with my local guy to get a bunch of parts we don't need ...
I hope this helps anyone looking for just the gasket
__________________
2006 Ford 350 - All the goodies - AKA : The best helper ever
Old Jun 18, 2014 | 10:15 PM
Yahiko's Avatar
Yahiko
Rep sent
Thanks Rusty for reposting that .
I knew that Julie had posted that and forgot to save a copy.
Do you happen to know if the D-rings for the stand pipes can be gotten
by them selves? When I pull the oil rail,2 injectors,do the intake cleaning
and install the BPD EGR cooler it would be nice to have fresh gaskets all around.
Sean
Old Jun 18, 2014 | 11:41 PM
Jnm2359's Avatar
Jnm2359
Thanks Rusty, as always you guys came thru again. I will check at my local international dealer.
Old Jun 19, 2014 | 06:00 PM
cheezit's Avatar
cheezit
Whats wrong with the old gasket?
Old Jun 19, 2014 | 06:21 PM
Jnm2359's Avatar
Jnm2359
I read that donut gasket was not reusable. So I started looking around and found it was hard to find individually.
Old Jun 19, 2014 | 11:15 PM
9228.bobcat's Avatar
9228.bobcat
You can re use them as long as they are not tore up or flat.
Old Jun 20, 2014 | 12:02 AM
Yahiko's Avatar
Yahiko
Don't forget "aircraft mechanic"
Job interview tomorrow and don't want to forget that certification card at home.
Always good to show your potential new boss that you do have that FAA card.
I really want to go back to work!!
Sean
Old Jun 20, 2014 | 12:10 AM
Jnm2359's Avatar
Jnm2359
Great news, it looks like new when cleaned up. thx
diesel_dan's Avatar
diesel_dan
Sean
GOOD LUCK!!! Tho we all you know you don't need it, they are fools if they don't hire you Sean....
Old Jun 20, 2014 | 12:20 AM
Super Duty Service's Avatar
Super Duty Service
Former Vendor
I've gotten burnt before reusing the donut gasket. Not a quick fix if it doesn't seal back up. But before the one that burnt me,, I reused them before. But never again will I not replace it. I look at them as the next in line to replace behind the rocker box gaskets. They might look ok,, but is it worth the chance?? I try n only get burnt once. Doesn't always work tho. Lol. Sometimes I need to touch the stove twice before I figure out its hot!!! Lol.
Old Jun 20, 2014 | 12:28 AM
Yahiko's Avatar
Yahiko
Thanks Dan, Me too.
Not working is making me crazy.
Anthony does Julie have a part number for the D-rings on the
new style stand pipes?
Sean
Old Jun 20, 2014 | 07:37 AM
Jnm2359's Avatar
Jnm2359
I actually took a chance and ordered a deplorable set and the set for only 48.00 came with it and a few other miscellaneous orings and gaskets.
Old Jun 20, 2014 | 06:27 PM
cheezit's Avatar
cheezit
Ive been burn too, but they only take 15min to swap out.... if you short cut it.
