1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Vaccum control solenoid
Old 06-18-2014, 05:01 PM
kx450frider617's Avatar
kx450frider617
kx450frider617 is offline
https://www.rockauto.com/catalog/mor...php?pk=4913382
My HVAC system would only blow through the defrosting vents so I traced the vacuum leak to this solenoid. I took the solenoid apart and found a torn diaphram, causing the air leak. Would this part be wants causing my HVAC to only blow air through the defrosting vents? I rigged a vacuum line that bypassed this straight to the HVAC system and I was able to switch vents.
I just want to be ordering the right part the first time. I am 99% sure this is my problem.
Old 06-18-2014, 05:04 PM
bpounds's Avatar
bpounds
bpounds is offline
Yes, and it is very common.
Old 06-18-2014, 08:45 PM
Lou Braun's Avatar
Lou Braun
Lou Braun is offline
I just had to replace an intermittent solenoid (same one). That solenoid also controls vacuum to the 4WD auto hubs. My 4WD would very occasionally refuse to work in automatic mode.
Last week it died and stayed dead long enough to trace the problem to that solenoid. Easy fix but sometimes frustrating to track the problem down.
Lou Braun
dwpick1030
01-09-2019 04:29 PM
CurtisNova
04-01-2014 10:39 PM
CaptKen
08-03-2013 08:02 AM
rmilchman
21
08-18-2011 03:46 AM
Argus21
04-26-2009 05:43 PM
Quick Reply: Vaccum control solenoid
