Sponsored by: Real Truck
Odd Vacuum Problem
Old Aug 2, 2013 | 11:02 AM
CaptKen's Avatar
CaptKen
Odd Vacuum Problem
02 F250 with 7.3. When I activate the 4WD, my light comes on, the A/C quits blowing out of the forward vents and goes into defrost and no 4WD. If I sit and wait a bit, the air again blows out the front vents and the 4WD engages. I figure I have a vacuum leak somewhere in the 4WD system. Is there a common place for this to happen or do I need to trace the whole system down? Also my manual hubs has never been turned and of course they won't. I know better than use a wrench so is there a easy way to free them up or just go ahead and disassemble and clean?
Old Aug 2, 2013 | 09:42 PM
redford's Avatar
redford
FTE Leadership Emeritus
Do you have a manual 4 wheel drive system (has a lever in the cab) or ESOF (has a switch in the cab)?
Old Aug 2, 2013 | 09:54 PM
CaptKen's Avatar
CaptKen
Switch on the dash.
Old Aug 3, 2013 | 08:02 AM
projectSHO89's Avatar
projectSHO89
You have vacuum leak in the ESOF system. Very, very common.
Check the PVH solenoid next to the battery and check the vacuum lines down to the hubs. One of them is leaking.
mkoser
Jul 11, 2015 04:51 PM
gpdickert
1983 - 2012 Ranger & B-Series
Jul 4, 2013 09:01 PM
terry_opie
Dec 18, 2008 09:53 AM
bbergman
Feb 3, 2008 04:55 PM
SteveH-CO
Sep 8, 2005 11:58 AM
