power steeing
Old Jun 16, 2014 | 08:06 PM
mike k m's Avatar
mike k m
power steeing
I know this has been asked several times and I've read multiple post about converting from manual steering too power, my question is will I have too cut or alter my steering shaft? I purchased a 1979 f100 with power steering and it also has a 3 speed column shift, thanks
Old Jun 16, 2014 | 10:32 PM
Shadowrider123's Avatar
Shadowrider123
I neat trick I ran across somewhere if you don't want to cut the end of the steering column is to flip your original steering wheel over and look at the underside.
There is a metal plate that holds the rubber spacer to the horn ring. The 79 steering shaft is to long and it will hit this metal plate when you try and install your 65/66 horn ring.
Take that metal plate off and drill a hole in it big enough for the excess steering column to pass through, then reassemble.
Old Jun 17, 2014 | 05:50 AM
jowilker's Avatar
jowilker
Mike the 7?-79 Saginaw power steering sets are the same overall length as the 65-66 non power. The difference is the Saginaw gear has hydro connections on top that move the connect point about 2 1/3 in closer to the firewall, making a column swap (easiest) or cutting the shaft necessary.
I run the 76 donor column in my 66. The dash cuff will need to be transferred or longer bolts used.
John
Old Jun 17, 2014 | 06:09 AM
mike k m's Avatar
mike k m
John
Thanks john, just the info I was looking for, I want too use my original column so I may just leave it the stock manual steering.
mrpotatohead
Sep 14, 2017 04:47 PM
oldblu
16
Jun 8, 2011 05:10 AM
65fordguy
Oct 12, 2008 09:55 PM
pcta12
May 18, 2006 07:34 AM
Cory Elliott
13
Jun 30, 2002 06:06 PM
