Steering column
Old Sep 13, 2017 | 11:02 PM
mrpotatohead's Avatar
mrpotatohead
Steering column
I need a steering column for my 66 with a floor shifted 4 speed. Does anyone know if one from a 67 is the same?
Old Sep 14, 2017 | 09:45 AM
svolpone's Avatar
svolpone
do you mean the steering shaft or the outside column. I used a 67 in my 64, but I had to cut it down some. I know the 66 is way different than the 64, though.
Sorry, my contribution is dubious at best here. I'm sure other experts will chime in.
Old Sep 14, 2017 | 04:47 PM
RangerMercMan's Avatar
RangerMercMan
The 66 and 67 columns should physically interchange so long as they are both manual steering. The steering wheel however, will fit on the splines of a 67 shaft but the shaft will protrude much higher and prevent you from putting the horn button or ring on. I am not a numbers purist I just go with what fits. Use the 67 steering wheel.
Elcid
Apr 20, 2016 11:41 PM
ssandirene
Feb 19, 2015 11:28 AM
R. Victor
Sep 23, 2013 12:16 PM
65fordguy
Oct 12, 2008 09:55 PM
tip49
Sep 8, 2008 07:12 AM
