Off topic, Case IH tractor help
Old Jun 14, 2014 | 03:52 PM
540milotalon's Avatar
540milotalon
I have a '05 Case IH JX1090 U cab tractor and the A/c compressor clutch is not kicking in. I'm thinking it's low on freon but would like to see some sort of service manual.
Suggestions? thanks
Old Jun 14, 2014 | 07:37 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Too new for me to help... If its low, the compressor should be running more than normal is about all i know.
Old Jun 14, 2014 | 09:15 PM
fordhorse's Avatar
fordhorse
You may need an ac pressure switch i think its this one. PART NUMBER: 530-4025
AP AIR, INC - Part Details
Old Jun 15, 2014 | 12:33 AM
Red454sedgwick's Avatar
Red454sedgwick
You need to tell us your pressures before we can really help. If you have 70psi "or close to it" of static pressure, just sitting not running, it should be full of Freon. That's normally enough to kick the clutch in to start.
Old Jun 15, 2014 | 10:08 PM
540milotalon
I found out no power to the compressor or the low pressure switch. The control panel overhead has a riostat type switch and it's bad. I jumped it out and the compressor clutch locked in. Thanks for looking.
nitro3421
Nov 5, 2012 09:56 AM
phurst
33
Jun 2, 2010 12:13 AM
cobramustangboy
Jul 3, 2007 12:43 AM
spivster
1997 - 2003 F150
May 23, 2007 02:53 AM
norrislaketn
Aug 24, 2003 10:21 AM
