dads f150
Old May 7, 2002 | 02:52 PM
hjames's Avatar
hjames
dads f150
My dad has an 88 F150 4.9i6 it is running rough I had him do a tune up and the next problem was as it was running out of fuel. I had replaced the fuel filter about 6000 miles ago and fuel pump under drivers seat on frame does not have duel fuel filters.
It started running worse sounded like a clogged cat from what he was telling me. I had him replace both cats, o2 sensor and new muffler. Has had fuel pressure test said it was 43psi? Now coming up with codes 67, 33 and 31. one of the codes says bad computer. Since I am in Ohio and he is in New Orleans I cannot run there each time something is wrong. I need to find somewhere where I can find out what the codes mean. Therefore, I can have some kind of idea what I need to get to fix this. Thanks
Has no power, misses out, bucks at 45+, top speed 57mph, and idles rough
Old May 7, 2002 | 08:49 PM
pancake's Avatar
pancake
dads f150
well hjames,31 is signal voltage for egr valve is below minimum spec
33 is egr is not opening or is not closed all the way
and 67 is improper signals coming from1 of these(neutral drive switch,neutral gear switch,neutral pressure switch,clutch switch ,manual lever position sensor ,or air conditoner clutch
so this tells me 1 thing atleast it is pointing at the egr valve
the best of luck to you ,dave
owner / driver 86 f-150 2wd auto ,efi v8 302
85 ranger 2wd auto 2.8 carb v6 150,000 miles and still going
Old May 10, 2002 | 07:29 AM
hjames's Avatar
hjames
dads f150
thanks for the info I thought it was the egr but not sure
Old May 10, 2002 | 08:19 AM
hotplate2's Avatar
hotplate2
dads f150
Cajun4396
2009 - 2014 F150
Oct 10, 2014 01:32 PM
Evolution Speed Shop
20
Jan 4, 2012 09:54 AM
JGarwood
Sep 15, 2008 07:30 AM
jimb522
Sep 19, 2007 09:48 PM
beeglej
Aug 25, 2006 04:36 AM
