Sponsored by: Auxito
Fuel Filter change/battery Neg cable
Old Jul 8, 2003 | 03:16 PM
sjalaska's Avatar
sjalaska
Afternoon, first I want to thank all participants on this site. The info that is shared is great.
Ok, a week or so ago I changed my fuel filter. In the "how to" instructions I found it tells you to remove the neg cable from the battery. Is this for safety reasons? Or is this so after you are done and it is replaced, the computer resets itself and make to required changes with the new fuel filter?
I was told by my neighbor, a 20 yr plus mechanic with Mazda/Ford, told me that removing the neg wasn't really necessary.
Bottom line, since I didn't take the neg cable off, should I go and do it which would allow the computer to reset.
If I should, should I only take the neg off and how long should I leave it off?
Thanks for any info.
Steve
Old Jul 8, 2003 | 03:39 PM
JeremyH's Avatar
JeremyH
I have never done that on any vehicle.
Old Jul 8, 2003 | 03:43 PM
Bob Ayers's Avatar
Bob Ayers
Removing the negative battery terminal is strickly for safely
reasons. When opening up the fuel system, you want to make sure you try to eliminate any sources of a spark.
Old Jul 8, 2003 | 04:07 PM
dbeames's Avatar
dbeames
The Negative battery cable is connected to the frame of the vehicle. The frame is an electrical conductor. It returns all the electricity from the component back to the battery, closing the circuit. When you remove the neg. cable, it opens the circuit, therefor nothing electronic in the car will be working; eliminating the chance of a spark that would ignite the fuel system (since it runs down the chassis. The "manuals" telling you to remove the cable is a CYA. Cover Your...
D Beames
Old Jul 8, 2003 | 04:46 PM
sjalaska's Avatar
sjalaska
Thanks for the quick responses. Just had me wondering after I read another thead in regards to cleaning the MAF sensor. The guy cleaned his MAF and his truck still had the same issues as before. One of the responses questioned if he removed the neg to allow his computer to reset itself based on the changes.
again, love the shared info
Peace
Old Jul 8, 2003 | 05:54 PM
LxMan1's Avatar
LxMan1
Actually the voltage travels from Neg to Pos. But you get the idea.
Jimmy
Old Jul 8, 2003 | 06:49 PM
elwhoppo's Avatar
elwhoppo
Removing the Negative Battery cableis purely a safety precaution in this instance.
However, I learning very quickly that, if I am working on any part of my vehicle, where I am expecting enhanced performance from the engine, it is bast to remove the Negative Battery Cable, to allow the Computer to reset & relearn.
I've seen many a vehicle computer still adjusting for malfunctioning symptoms, as though the old part was still attached.
After a while, the Computer will relearn, but why not start off fresh, instead of wracking your brain for days, wondering if your inept.
Its nothing to pull the cable, and let the Computer reset. Saves relearning time, and gives your ego a more timely boost.
Many of us look at vehicle repairs through the eyes of "Mr. Macho". Thinking, "I can do that repair without taking off the cable, I'm a big boy, I know what I'm doing, I won't short it out, and burn the vehicle to the ground".
I'm a Man!!!
Well, we hear you and understand the image thingy, but Guy's & Gal's,
"Remove that Negative Cable", "Reset the Computer"!!
First, always for safety purposes, don't ever forget "Static Electricity". And Second, if you are thinking, or expecting some performance enhancment results from your repair.
Maybe there won't be a dramatic change, but maybe there will be, with the Computer reset, to learn the improvement your repair may have made.
Old Jul 8, 2003 | 06:56 PM
dbeames's Avatar
dbeames
Am I right in stating that removing the neg battery cable only resets the codes in the system. Not the PCM itself? I thought you had to have a scanner to actually reset the entire computer. Disconnecting the battery cable only clears codes. Or so I htought.
D Beames
Old Jul 8, 2003 | 07:11 PM
elwhoppo's Avatar
elwhoppo
Hmmmmmmm. Now you got me wondering!
My understanding is that, the Computer itself, is reset to a "no trouble codes" mode, and if there are still problems, it will eventually relearn them, display them, so you can tell if you are actually making corrective repairs.
Maybe I should sit back and let a real live Electronic's Whiz add to this inquiry.
Until then, it may be best to ignore my initial response to this thread.
Elwhoppo to Whiz, come in Whiz!!!
Old Jul 8, 2003 | 08:27 PM
Racerguy's Avatar
Racerguy
Pulling off a battery terminal for any length of time should clear the PCM's KAM (Keep Alive Memory) and it's learned tables. Ford says this in the manual when replacing a battery.......
NOTE: When the battery (10655) has been disconnected or reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its fuel trim. The vehicle may need to be driven 18 km (11 miles) or more to relearn the adaptive strategy.
NOTE: When the battery has been disconnected or reconnected, volatile memory information will be lost. The affected systems will have to be programmed by the technician or customer. These systems include radio station presets, clock settings, and customer input keyless entry codes.
Old Jul 9, 2003 | 12:01 AM
dbeames's Avatar
dbeames
If voltage travels from negative to positive, then why do we always put the fuse on the positive wire. Seems to me that it flows in the opposite direction. The negative wire is the ground, the return.
D Beames
Old Jul 9, 2003 | 10:51 PM
dbeames's Avatar
dbeames
I see what you are saying. I thought that was the difference in A/C and D/C though. Alternating switched (why we use alternator's instead of generators) and D/C went straight through. Maybe I am thinking of something different. I can see how it would attract though. But have you tried to take a voltage reading of the Negative wire of something? Doesn't quite work. So that is why i though that the negative was the return.
Old Jul 10, 2003 | 12:00 AM
Racerguy's Avatar
Racerguy
oops sorry lxman when I got rid of your duplicate posts I got rid of the one I should have kept too.
sorry
Old Jul 10, 2003 | 05:18 AM
Bob Ayers's Avatar
Bob Ayers
D Beames
The negative terminal (or ground) will have the sum of all the
currents from the positive terminal. The fuses are put in the
positive side, so individual circuits can be protected from
excessive current.
Old Jul 10, 2003 | 11:29 AM
LxMan1's Avatar
LxMan1
That's ok Dave, I think they got the idea
wahlturfcare
Sep 26, 2014 10:57 PM
austinjorg
Jan 21, 2005 02:04 PM
78-96BigBronco
1978 - 1996 Big Bronco
Jul 18, 2003 10:33 PM
Violator
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 18, 2003 10:52 PM
Rtpjunior
Jun 14, 2003 12:55 PM
