Which driven gear do I need?
Old Jun 12, 2014 | 09:55 PM
big-ugly's Avatar
big-ugly
I've researched this before but never got around to correcting my speedometer. After using one of those nifty calculators I found online, I come up with needing an 18 tooth driven gear. Truck is a '74 F250, np435, 205 xfer case, 4.10 gearing, and has 37" tall tires. Does that sound about right to any of you? How close would a 16 tooth driven gear get me? Any help is appreciated.
Old Jun 13, 2014 | 12:30 AM
Fordworth's Avatar
Fordworth
The change in accuracy from gear to gear will vary from combo to combo however each tooth is generally worth about 2 to 3 miles an hour as read on the speedo. Therefore if you need an 18 tooth gear a 16 tooth would be off by 4 to 6 miles per hour. I have a 16 tooth gear in mine with 38 inch tires and 3.73 gears and it reads correctly. With your 4.10s it would be off significantly.
Old Jun 13, 2014 | 09:30 PM
lafermedavid's Avatar
lafermedavid
speedo
What was stock for your 74,Im sorta right on line with you BU,,4/10 37inch rubber,,,transfercase speedo
Old Jun 13, 2014 | 09:56 PM
big-ugly's Avatar
big-ugly
Thanks for the replies guys. I don't know what is stock, as I have not had mine apart yet. I don't really want to take it apart until I have the replacement gear in hand.
Old Jun 14, 2014 | 08:02 AM
lafermedavid
speedo
ok mine is stock,its 18 gear tooth,t/c speedo cable,,,I guess ill run that one along side a gps and compare
Old Jun 14, 2014 | 03:16 PM
big-ugly's Avatar
big-ugly
Please let me know what you find. I would really like to start daily driving my '74 to work, but I don't want to until I know I can get an accurate mileage count for checking fuel mileage, changing oil, etc.
Old Jun 14, 2014 | 05:23 PM
lafermedavid
18 tooth
hey brandon it will be awhile;till im on the road.Im putting motor in soon.Working on brake lines now.I would go with that 18,after what Fordworth said.
Old Jun 14, 2014 | 06:39 PM
406angler's Avatar
406angler
call the ford dealer and ask for P/N c0dd-17271-b (18-tooth speedo gear) that's what I'm using with 4.10's NP205 and 315/75r16's (34.6" tall tires)
Old Jun 14, 2014 | 10:28 PM
lafermedavid
<TABLE border=0 cellSpacing=0 cellPadding=6><TBODY><TR><TD class=itemlink colSpan=2>Speedo driven gear 18 teeth (gold or yellow) </TD></TR><TR><TD vAlign=top width=60><IMG border=0 alt="New
1966-96 Ford Bronco
1973-96 Ford F100, F150, F250, F350
1984-90 Ford Bronco ll
18 teeth
gold or yellow
" src="http://broncograveyard.com/images/catalog/SPEEDOGEART.JPG" width=60 height=60>
</TD><TD class=normal vAlign=top># 37192C
</TD></TR></TBODY></TABLE>Bronco Graveyard
Old Jun 14, 2014 | 10:34 PM
big-ugly's Avatar
big-ugly
Wow thanks guys. Wouldn't my speed-o still be off with an 18 tooth gear though? 406Angler mentioned that he was using an 18 tooth gear with 34 1/2" tires. I am running 37", so would I need a gear with more tooth count?
Old Jun 14, 2014 | 10:44 PM
lafermedavid
speedo
trial and error.18 19 20,,,I have an 18 Ill go from there,but I will post once i figure it out
Old Jun 15, 2014 | 01:50 PM
redroad's Avatar
redroad
Have a look here
Zachthemoo2
Oct 2, 2014 04:42 PM
Mr7.50headsup
Feb 20, 2014 11:22 PM
btracy
Jan 8, 2013 05:46 PM
Greyf100
Apr 26, 2009 04:38 PM
Ray D
16
Feb 10, 2001 08:49 PM
