P0238
Old Jun 12, 2014 | 03:05 PM
HT32BSX115's Avatar
HT32BSX115
P0238
Howdy guys (&gals!)
Well, fist time out and I've got a P0238.
28000 miles since new on this '05 F350.
Towing a fairly light load. Got in on a hill. Boost press is less than the redline on the pull.
I don't have the scan guage set up yet to read boost. Guess I should do that.
I've cleared the code and will see if it comes back. I guess it could be the sensor or even a sticky unison.
Anybody?
Regards
Rick
Old Jun 12, 2014 | 07:20 PM
npccpartsman's Avatar
npccpartsman
P0238 Turbo/Super Charger Boost Sensor A Circuit High Default inferred MAP - low power, slow acceleration, MAP
voltage is greater than 4.91
MAP circuit short to Vref or Vbat, defective sensor.
Old Jun 12, 2014 | 10:00 PM
HT32BSX115's Avatar
HT32BSX115
Thanks.
There's no indication of power loss.
Im thinking its a sensor problem. In about 500 miles, it only did it twice on 5 pretty hard full throttle pulls.
Now that think about it. I believe I saw the boost gage abruptly go to zero momentarily at one time. Maybe some chafing going on?
Old Jun 13, 2014 | 05:16 AM
npccpartsman
Maybe, but I would pick up a MAP sensor just in case.
Old Jun 13, 2014 | 04:52 PM
HT32BSX115's Avatar
HT32BSX115
Looks like I need to program my SGII to read Baro and MAP and see if they read the same KOEO.......
Old Jun 20, 2014 | 03:00 PM
HT32BSX115's Avatar
HT32BSX115
Update. It did it again on the return trip, under a pretty good load going up a hill.
I also observed the instrument panel gage go momentarily and abruptly to zero right before it set the P0238.
It appeared to slightly reduce power when the gage went to zero but maybe the ECM tries to reduce fuel flow when it senses an abrupt reduction in boost.
Shaun Fed
6.4L Power Stroke Diesel
Jul 25, 2019 05:12 PM
JGRNAUT_7.3L
Dec 2, 2017 11:07 AM
Tugly
May 9, 2014 07:49 AM
bobrc
Aug 24, 2008 12:56 PM
teamroper98
Jun 1, 2006 09:07 PM
