Sounds like a shorted headlight switch?
Old Jun 11, 2014 | 11:13 PM
IDIDieselJohn's Avatar
IDIDieselJohn
So on my '91 E250 Club Wagon, I have an odd short somewhere, in the dome light system, witch is on the same fuse for the radio.
If I turn the key back to ACC, and have the radio playing, and open the side doors, as soon as the door opens, and the dome light comes on, the fuse blows.
I took the dome light bulbs out, and same problem.
Now with all doors closed, radio on, if I turn the headlight switch to the left to turn on only the dome light on, fuse blows. Same thing with radio off.
It only happens with the side doors, as the 2 front doors, the little button thing that pops out when you open the doors to turn the dome light on, doesn't work.
Does it sound like a short somewhere in the dome light thingy alone? Or in the headlight switch? Makes no difference if there is a bulb or not in the socket, soon as I turn the lights on, fuse blows.
Any ideas as to what, and how to diagnose this? I'm terrible with electricals.
Old Jun 11, 2014 | 11:28 PM
genscripter's Avatar
genscripter
let me take a look at my club-wagon electrical schematics and see if there is anything that pops out.
Old Jun 12, 2014 | 04:49 AM
ifrythings's Avatar
ifrythings
Roof dented? If it is then it's probably touching one of the screws that is used to mount/supply power to the dome light
Also check the bad door switches incase there shorting the bk/lb wire to ground.
Old Jun 12, 2014 | 10:59 AM
IDIDieselJohn
I'll check that out, and nope, the roof on this van is absolutely mint.
Old Jun 12, 2014 | 02:23 PM
jas88's Avatar
jas88
First thing I would do is remove the screws that hold the dome light housings in and let them hang. This will tell you if the short is at the housing or in the wiring itself. One of the 2 screws is for ground, the other is hot and has an insulator to keep it from shorting out. Maybe one of the insulators wore thru?
Old Jun 23, 2014 | 07:00 PM
IDIDieselJohn
Alright, update on this.
I removed the 2 front door switch things that open the lights when you open the door. The drivers one was super corroded and a little prong was gone, I disconnected it, and problem solved......for about a week.
Sunday in at my friends campground, had the side doors open on the van, and sitting around it, out of nowhere I see the dome light turn off...and sure enough fuse blown.
So when I get home, I removed all the door switchs, turn the light **** to turn on the dome light, bang fuse blows.
So I remove both dome lights, the whole assembly, bang again soon as you turn the head light switch **** for the dome light.
So any ideas from here? Could it be a bare wire somewhere inside the body? and if so, how can I find where, how do I test for that, or does it sound like a shorted fuse box or headlight switch?
I took the headlight switch out thinking that might be it, but the switch looks mint, as well as the connector, so i'm stumped!
Ole Green 1978
22
Dec 23, 2017 08:03 PM
Spidermanmike
Aug 22, 2017 04:00 PM
xluckyxbulletsx
Aug 13, 2009 11:42 AM
k6mms
15
Sep 22, 2003 10:16 PM
