Battery Light After 3G Install
Old Jun 11, 2014 | 09:42 PM
brainbone's Avatar
brainbone
Well folks I've hit the point where I need to ask what I'm doing wrong. The truck is an '87 F250 6.9 new style glow plugs / controller.
I went to do the 3G alternator swap as my battery light had been flickering on and off ever since I got the truck. Got the connector from a 3.8 Taurus and alternator from a 1994 3.8 Windstar. Wired everything up as shown here https://www.ford-trucks.com/forums/1...3-92-idis.html
Still got the battery light coming on but now it's on solid. I've got the alternator tested at Autozone and it's good. I checked all my connections and they're good after replacing my connections to and from the megafuse.
I decided to put a bolt in the back of the case and run a grounding strap to the body just to be sure!
Still, the light stays solid and I'm getting ~11.6V at the battery. Any ideas? I've gotten a lot of people saying I'm probably not getting it grounded...
Old Jun 11, 2014 | 11:34 PM
genscripter's Avatar
genscripter
what voltage at the battery do you get when idling? or when revving?
Old Jun 12, 2014 | 05:14 AM
ifrythings's Avatar
ifrythings
Do you have the S terminal of the regulator plugged into the alt?
Is the A terminal going to the starter solenoid main lug along with the output wire of the alt?
Old Jun 12, 2014 | 06:50 AM
brainbone's Avatar
brainbone
I'm getting 11.6V regardless of revving or idle. It's seems like the alternator isn't charging or doing anything.
Yes the jumper clip is plugged in from the S terminal. The A wire is run to the charging post. The cable from the charging post goes directly to the battery positive rather then the starter solenoid.
97ranger xlt
1983 - 2012 Ranger & B-Series
Dec 28, 2012 06:59 AM
medic25
Dec 10, 2012 02:20 PM
noel431
2004 - 2008 F150
Apr 18, 2010 02:35 PM
curtc
Electrical Systems/Wiring
Nov 7, 2008 10:30 AM
Chumbucket
Aug 8, 2006 03:10 AM
