Fuel return pressure question
Old Jun 11, 2014 | 02:32 PM
chh's Avatar
chh
To determine if a plastic injector cap is leaking vs. a metal injector line would pressurizing the system without running the motor (electric pump) be a good test?
I'm assuming that the IP allows pressure to the injectors only when it is running and that the return system would be pressurized via the return line from the filter housing to injector 1)
So, if there is a leak and there is no pressure at the nozzle then it must be the plastic cap.
Does this sound right?
Old Jun 11, 2014 | 08:37 PM
Macrobb's Avatar
Macrobb
Yes, basically.
88 Ford IDI
20
Feb 17, 2016 06:31 PM
halfbrit
Nov 19, 2015 09:39 PM
ngng
6.7L Power Stroke Diesel
Nov 4, 2014 11:48 AM
ah1988
Sep 26, 2010 01:28 AM
albung
Feb 20, 2008 12:19 PM
