6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Fass pump
Old Jun 10, 2014 | 10:02 PM
brian1253's Avatar
brian1253
Fass pump
So I picked up a fass pump the other day and I found this
FASS filtration deception. - Dodge Diesel - Diesel Truck Resource Forums
Wouldn't ya know I found it right after I bought one and every body only talks about how great they are but it says in the posts the water separator doesn't even separate water untill gravity does it after the truck is off. Have they improved any since then? Should I try to return this thing? It says they have changed filter manufacturers since then but I'm skeptical they are trying to market a product.
Old Jun 11, 2014 | 04:59 PM
Booma's Avatar
Booma
Wow, what a read. I have to assume that Airdog must have the same issues since they are built by the same manufacturer. I just bought an Airdog 2 and now have some search to do, something I should have done beforehand. My fault of course. I am a new diesel owner and take a lot of stock in what I read here and naturally was horrified by the stories of injector/hpfp failures related to water issues. My decision to buy the aftermarket Airdog was only for the filtration and reliability it promised, not performance. So now maybe I have less water separation protection than OEM??????
Old Jun 12, 2014 | 02:02 AM
brian1253's Avatar
brian1253
We were lied to by people in marketing!! That never happened before!! But don't worry there's hope. It's all in the filters you use. There's water separators that take out over 90% water (both emulsified and not) and filters that take out water along with being a 3 micron filter. If you add up both filters at lets say 90% each you are left with 1% water left and that is at 90% some water separators are better. I have been doing some looking but am having trouble finding all of the specs on all of the filters that will work for me. If anybody already did this research feel free to chime in at any time. I only feel half ripped off.
Old Jun 12, 2014 | 02:07 AM
brian1253's Avatar
brian1253
Oh and air dog and fass is two different company's it's a father son thing and they had a falling out and one of them created the other company. I would guess they don't do business with each other. They are similar but different.
Old Jun 13, 2014 | 05:09 PM
Booma's Avatar
Booma
Been doing a little research and you are correct in that the sky is not falling. There are several manufacturers that produce excellent water/fuel separation filters. One of the best is Baldwin which has been tested to remove 99% free water and 96.5% emulsified water on every pass. My personal good news is that Airdog now sells their units equipped with Baldwin filters. But if you have an early Airdog the Baldwin part number BF1275 may be a good choice next time you change your filter.
Here's a link to a spreadsheet showing some filter spec's;
http://i79.photobucket.com/albums/j1...FilterData.jpg
Here's a link to one vendor who has a very good cross reference capability that you can use to find what will fit your FASS unit;
Filter Products
WolfFox
Nov 18, 2016 04:42 PM
oxt127
All Things Towing
Feb 20, 2016 10:18 AM
JonArmy
Sep 15, 2011 10:10 PM
sparkkky
Mar 25, 2011 12:12 AM
fordboy67
Appearance & Dress-Up
May 4, 2010 06:26 AM
