Water spots
Old Apr 30, 2010 | 11:14 AM
fordboy67's Avatar
fordboy67
Water spots
Has anyone tried the water filters sold at Menards or Home Depot to try to eliminate the hard water spots, if so what type of filter should I look for? Thanks in advance!
Old May 3, 2010 | 06:53 PM
ReAX's Avatar
ReAX
I haven't tried any other than the MrClean one. However, if it's like what I am thinking of, then they will not help much. The kind I have in mind are not much more than simple paper filters. The elements(minerals) that make up a lot of hard water run through paper filters and laugh at you. My reading say you have to have a resin that the minerals bond to or cause the minerals to fall from suspension in the water.
Old May 3, 2010 | 08:45 PM
fordboy67's Avatar
fordboy67
I have actually had pretty good luck with the MrClean, but can't find the soap or filters for it around here anymore, do they still sell them?
Old May 3, 2010 | 10:10 PM
big poppa's Avatar
big poppa
Not sure how you can remedy the hard water part but as for the spots on your paint guys used this Clay Bar on the vehicle. I never seen it but I assume its like a bar of soap type rubbing compound, heard good things about it, wished it was around here. Hope this helps with the waterspot removal.
Old May 4, 2010 | 06:26 AM
ReAX's Avatar
ReAX
That is my current solution, only problem is the clay bar strips off all of the wax. So after washing and claying, you have rewax it. Clay bar kits have become very popular, check out your local auto parts stores (Advanced in particular I know carries them). They are available from Turtle wax, Mothers, and Meguires.
TexasGuy001
Appearance & Dress-Up
Mar 24, 2010 08:01 AM
Adamjr
Garage & Workshop
Dec 30, 2009 10:04 AM
mblanken881
Jan 11, 2009 09:45 PM
cornfeed
Jun 1, 2004 12:28 PM
