Vacuum advance question
Old Jun 12, 2014 | 12:21 AM
Tedster9's Avatar
Tedster9
Does it respond quickly (neutral) when you blip the throttle fast? That's another easy test. A well tuned engine will be noticeably snappy, without a bog or flat spot hesitation. Revving up an engine in neutral isn't high on my fun stuff to do either, but 18 degrees indicated is about HALF of what you need, (assuming the mechanical advance is all in.)
Good deal, you may be on to something! You need to investigate further. Use a tach, and determine for sure what total timing is at, all the way up to 4000 or so. Be sure to disconnect vac advance for this check.
Likely your old distributor is gummed up and worn out, sticking, etc. How you achieve the 36 to 38 degree sweet spot is up to the tuner. Usually a stock engine and distributor has way too much mechanical advance, plus, that advance only comes all in at about 4500 RPM, (too late) something like that, and uses very little initial (crank) timing. This allows for hauling very heavy loads without detonation. Think dump truck on a mountain grade. But, it's a "dog".
By limiting the distributor mechanical advance and installing lighter springs, we still keep that same 36 to 38 degree total timing but the ratio and RPM is different. Instead of 4 or 6 degrees crank timing, we can now dial in say,12 or 14, and the advance will come in between 2500 and 3000 RPM. Makes for a lot better performance.
Old Jun 12, 2014 | 01:35 AM
85e150's Avatar
85e150
Point taken on the 70 in a mile, clearly even a good 360 running on 6 cylinders will do that easily.
Once you sort out the timing, think fuel. You may be getting enough at idle and low revs, but it might crap out when you are under a good load. Had one do that--it would run ok till you got on it, then it would cut out after a little bit of acceleration.
Check the filter & see if it's clogged and maybe more junk in the tank.
Check the float level.
Old Jun 12, 2014 | 07:16 AM
yetiman38237's Avatar
yetiman38237
I really need to take the time to do this. I have done the re-curve with a different mfg and it made a huge difference. I also need to purchase a petronix system.....
Old Jun 13, 2014 | 08:37 PM
AK FORD GUY's Avatar
AK FORD GUY
http://www.fordmuscleforums.com/all-...stributor.html
Different engine, similar situation. The port you are not using needs to be open, not plugged. It is not allowing your vac advance to work properly.
Old Jun 14, 2014 | 08:39 AM
raven3's Avatar
raven3
The stock 2V caburetor has two vacuum ports.
One on the front ,drivers side and one on the side, passenger side.
Which of the two ports is connected to the disbributor vacuum advance port?
Old Jun 17, 2014 | 01:32 PM
maverick600's Avatar
maverick600
Mine is an old Holley 2bbl but the vac advance is connected to the pass side port. It doesn't have one on the drivers side.
Old Jun 17, 2014 | 01:36 PM
maverick600
I have cleaned out the fuel tank, changed the fuel filter on the fuel pump and also installed another filter right where the fuel line from the tank comes out below he tank. Also I have double checked the float level on the carb. Thats the one good thing about holleys is that they are easy to adjust.
Old Jun 17, 2014 | 01:39 PM
maverick600
Yes it does seem to respond quickly in neutral. I did some reading on adjusting holley carbs and they say to get it to operating temp and put the vehicle in drive to adjust carb. I did this with a vacuum gauge and adjusted the highest setting, both sides at the same time. It doesn't seem to bog down much anymore at low speeds now but it still just seems sluggish.
Old Jun 17, 2014 | 01:42 PM
Tedster9's Avatar
Tedster9
What is the total mechanical advance throughout the RPM range?
Old Jun 17, 2014 | 01:47 PM
maverick600
Still have not acquired a tach.....I am at a fire chiefs conference this week out of town I will mess with it next week and hopefully be able to report some true numbers.
I was speaking to a mechanic friend and he was saying that I should only get about 8 degrees out of it which is way different than you guys. I just went on after that since you guys have more specific details with these engines than he does.
Old Jun 17, 2014 | 01:51 PM
maverick600
I am also starting to question my ignition, since I installed the pertronix II with their coil I have not seen much of a difference. I went with the II cause they had said that I could use the same wiring that came with the truck meaning I didnt have to bypass the resistor wire or whatever its called. Just to see if there is a difference where do i need to run a wire to from the positive side of the coil to see if it will in fact make a difference?
Old Jun 17, 2014 | 02:20 PM
redroad's Avatar
redroad
What distributor did you convert with the pertronix II ? and is the 360 original to the truck ? and if not what year is the engine ?
Old Jun 17, 2014 | 02:37 PM
  #28
Tedster9's Avatar
Tedster9
You don't need a tach. Please re-read the entire thread, for comprehension/understanding. Jeez.
Old Jun 19, 2014 | 07:56 AM
  #29
maverick600
Stock distributor and as far as I know its the original 360 and its 43 yrs old.
Old Jun 19, 2014 | 07:59 AM
  #30
maverick600
I did re read entire post. I do understand what you are asking for...I just wanted a tach so I can give accurate numbers. The most I have seen it advance while using a timing light with vacuum advance unplugged and capped off is about 15 degrees but I dont know what rpms were at.
