ip firing order
Old Jun 10, 2014 | 04:44 PM
brokeasajoke's Avatar
brokeasajoke
ip firing order
Ok so I pulled a dumb move and made a boo boo. Pulled my ip off and sent it to idiperformance and failed to write down or number how the injector lines go back on. Could someone be so kind as to tell me the order in which they go back on. Thanks much.
Old Jun 10, 2014 | 08:49 PM
Orpackrat's Avatar
Orpackrat
https://sites.google.com/site/oldforddiesels/28385IP_lines_info_02-med.JPG
Old Jun 10, 2014 | 09:41 PM
Macrobb's Avatar
Macrobb
The great thing about our lines is it's pretty much impossible to get them on wrong.
If you just start placing lines in, fitting them between the IP and the injectors, you'll see where each line up. Once you have all 8 layed out, just hook em up, and you'll be right.
IIRC, there's only one which can be put on wrong, but the 'wrong' way makes it stick way up and over, not flat like it should be.
Old Jun 11, 2014 | 04:05 PM
brokeasajoke
Thanks guys. What is the number sequance of the cylinders. Ive found two conflicting answers to the cylinder numbers.
Old Jun 11, 2014 | 08:47 PM
Macrobb's Avatar
Macrobb
Uh, passenger side front is #1, rear #7, driver's side: Front #2, rear is #8.
Old Aug 27, 2017 | 10:32 PM
Rentaro's Avatar
Rentaro
Thanks, this is what I was looking for.
Old Sep 6, 2017 | 08:22 PM
90Ford73's Avatar
90Ford73
Thanks a bunch for posting this pic, I needed clarification on a couple of my lines as well!
ColoradoFordBoys
Oct 5, 2014 05:12 AM
87f250banks
Jan 1, 2011 11:57 PM
gomfrddy
Jan 23, 2007 01:43 PM
graderman
Mar 30, 2006 10:10 PM
carpe_diem
Aug 1, 2003 09:22 AM
