Sponsored by: Real Truck
Need HELP-BIG TIME !!
Old Jun 10, 2014 | 12:10 PM
n4gnr's Avatar
n4gnr
I have a 2008 F550 6.4 diesel which has given me no problem at all till yesterday...It is a work truck, light duty dump. It would not crank yesterday morning. The instrument panel did not light up, and the door chimes did not sound off. Looked aropund for a while under the hood, and gave up...Came back an hour later,, and it was normal. This morning,, same thing...no instruments...Batterys are full power, horn works, lights are bright,, radio plays, A/C blows air. I checked wiring around fuse boxes, pushed on harnesses, and nothing. I went in the house and looked on computer for answers, and 15 minutes later went back out and the door chimes were sounding off-i left doors open. This truck has GOT to run in the morning, and other mornings...WHAT in the sam hill could it be ??????It definately is something intermiddent...buit what ?? Could it be the body module ?? A relay somewhere ?? HELP !!!!!!!!!!!!!! Dan
Old Jun 10, 2014 | 02:54 PM
SteveH-CO's Avatar
SteveH-CO
Start by cleaning all the battery terminals. Do you have water leaking thru the windshield (was it recently replaced?) and into the dash and wiring? Check the carpet on the floor in the footwells, for wetness.
Old Jun 10, 2014 | 04:11 PM
senix's Avatar
senix
did you can for any codes?
I suspect a bad connection or ground.
I'd start with battery terminals and body grounds.
Old Jun 10, 2014 | 04:12 PM
n4gnr's Avatar
n4gnr
no, there is no wetness...windshield never replaced... the connections are good, very clean....
Old Jun 10, 2014 | 04:15 PM
senix's Avatar
senix
check the relays for corrosion or loose in the power distribution box?
trudiesdad
Feb 27, 2017 11:23 PM
whdahel
Oct 28, 2015 01:39 AM
D Lab
Escape & Escape Hybrid
Mar 27, 2014 01:04 PM
babstinger
Sep 6, 2010 06:44 PM
phillips91
2004 - 2008 F150
Nov 2, 2009 07:37 PM
