Sponsored by: Real Truck
BLOWN SPARK PLUG QUESTION
Old Jun 8, 2014 | 03:46 PM
scottblogs's Avatar
scottblogs
I had the #10 plug blow last month. Today the #9 blew. UUUGGG.
Anyways, truck is on the side of the road. Can I safely drive it without doing further damage etc? I would like to get it home while I research mechanics (I fell like I was overcharged last time).
I will call for a tow if driving will increase damage/risk or if it is a risk to myself.
HELP?
Old Jun 8, 2014 | 03:48 PM
Kdr358's Avatar
Kdr358
unplug the injector and COP and you will be ok to get it to where you have to go, it will be down on power and you will get a CEL and a very noisy ride.
Old Jun 8, 2014 | 03:50 PM
JWC 3's Avatar
JWC 3
X2 ... I have brought in many that way ...
Old Jun 8, 2014 | 03:52 PM
scottblogs's Avatar
scottblogs
Cool, thanks. How do I unplug the injector and COP? LOL I will see if I can find instructions somewhere...
Old Jun 8, 2014 | 03:55 PM
JWC 3's Avatar
JWC 3
Squeeze the release tab and pull the plug straight off
Old Jun 8, 2014 | 03:56 PM
scottblogs's Avatar
scottblogs
A bit of research shows disconnecting those may be beyond the scope of my mechanical abilities!
scottblogs's Avatar
scottblogs
Oh... that doesnt sound too bad...
Old Jun 8, 2014 | 04:00 PM
scottblogs's Avatar
scottblogs
So if I disconenct that electrical attached to the injector (no tools required) I am good to go? Do I need to take the COP off, or can I just leave it in place?
Old Jun 8, 2014 | 04:02 PM
JWC 3's Avatar
JWC 3
Unplug the connectors , you should be ok .
Old Jun 8, 2014 | 04:04 PM
JWC 3's Avatar
JWC 3
Oh .... When you get it fixed... HAVE ALL The plugs retorqued . That will help prevent this in the future . Best of luck !
Old Jun 8, 2014 | 04:19 PM
scottblogs's Avatar
scottblogs
Interesting what you say about having the plugs re-torqued - the last mechanic said to leave them all alone forever unless the truck miss-fires. Said not to touch them unless absolutely necessary. Man I hate miss-information from mechanics...
Old Jun 8, 2014 | 05:27 PM
DavidB's Avatar
DavidB
Misinformation is what you got. Stay as far away from that mechanic as possible. Plugs that are properly removed and properly installed rarely have problems. Yes, the head should have been designed differently. But plugs that are properly installed into an undamaged head do not blow out. Plugs that are improperly installed cause problems because of the head design.
Old Jun 9, 2014 | 11:03 AM
scottblogs's Avatar
scottblogs
Hi DavidB, thanks for your response. I both agree and disagree with your comment.
*IF* all plugs had been installed on my truck perfectly, I would agree with it. If they were installed properly all these years, I would say, yes, check them all, but the problem is the truck is 14 years old. Many owners. I have no idea of knowing what the threads are like for the rest, and with two blow-outs, I can assume that more will occur, making me want to stay far away from those threads which are possibly messed up.
You also note that when done properly there are rarely problems. I have to wonder about that. I have seen MANY stories where this has occurred with factory installed plugs. (Yes I suppose it is possible that those were installed incorrectly also, but seems less likely).
I have also heard at least one story where a person had a blown plug occur on that had been done before he bought his brand new truck! His mechanic found an insert. This guy was the original owner, meaning the repair was done when the vehicle was brand new!
What a stupid scary problem.
turbolaser
16
Apr 28, 2022 05:42 AM
makemeknowit
Modular V10 (6.8l)
Mar 6, 2019 11:32 AM
Deagle12
Modular V10 (6.8l)
Oct 31, 2017 12:24 PM
WMNY
Modular V10 (6.8l)
23
Aug 2, 2011 02:17 PM
swright_47
1997 - 2003 F150
18
Jun 3, 2008 08:41 PM
