Overboost Annihilator
Old Jun 7, 2014 | 06:27 PM
schlepprock250's Avatar
schlepprock250
Ok so years ago, I installed an Over boost Annihilator( thats what the vendor at the time called it anyway). I think it was recently turned by mistake ( but not by me ), can someone tell me how to adjust it correctly? Or any info on how I can check it? Thanks..Phil
Old Jun 7, 2014 | 08:16 PM
whitetmw's Avatar
whitetmw
Found this. Don't know if its what you're referring to.
http://goo.gl/6T6V8n
Old Jun 8, 2014 | 08:04 AM
mueckster's Avatar
mueckster
Phil,
Are you getting a SES light and "overboost" code since the **** was turned? I usually hook up a known accurate gauge to "fooler", bench test with regulated air (set @ ~25 psi), and adjust to ~22 psi before installing. I, then, "fine tune" after the test drive. I have found that my MAP will trip "overboost" at anything over 21.7 psi, according to my Aeroforce Scangauge. You can also use your AE, or other scan, tool, to monitor the manifold pressure. I adjust the regulator in fine increments, usually no more than a couple of notches from the initial setting, until there is no SES/code.
Old Jun 8, 2014 | 08:48 AM
tjc transport's Avatar
tjc transport
i ain't rite
i set mine with a pressure gauge on the outlet, and compressed air on the inlet. set it so i got no more than 20 lbs pressure on the outlet, then put it on the truck.
Old Jun 8, 2014 | 01:21 PM
CampSpringsJohn's Avatar
CampSpringsJohn
I installed one of these a couple months ago and it works great.
OCR - Overboost Code Regulator - Riffraff Diesel Performance
Old Jun 8, 2014 | 01:59 PM
schlepprock250
Thanks guys. I'm not getting a check engine light, but I'm pretty sure it was turned but I'm not sure which way or how many turns. I wasn't sure if I would suffer any kind of fueling issues or not, its probably paranoia and ocd kickin in. But thanks for the replies..Phil
Old Jun 8, 2014 | 02:32 PM
tjc transport
i ain't rite
it it was turned down it would not make any difference, just telling the MAP sensor you were only getting 17 lbs boost instead of 22.
it it was turned up though, you would know it, because you would get a SES light and de-fuel due to the MAP sensor seeing over boosting.
Old Jun 8, 2014 | 02:43 PM
schlepprock250
Yeah that's kinda what I was thinking but wanted a couple opinions to be sure..thanks.
Old Jun 8, 2014 | 03:21 PM
UP_There's Avatar
UP_There
Call Dennis at Strictly Diesel. He is the former owner of ITP Diesel, and he designed the OBA. Strictly's number is (480) 922-8768
Tugly
130
Jul 20, 2020 11:56 AM
FiznUKa
Dec 20, 2014 09:20 PM
natewoz
15
Dec 9, 2008 03:24 PM
lpg333
Feb 22, 2006 10:57 PM
