I believe I answered this but you seem to want to ask it again in another topic! I have one, have talked with others who have one, and I'll say one more time, GET IT REBUILT, THEY ARE OFFSET FOR A REASON AND YOU CAN'T JUST THROW ANYTHING UNDER IT!
Thanks for the pics maples. I learned something. Ive driven a lot of those vans and never noticed the offset. I used a 70 Econoline as a company work truck for about 5 years in the late 70s. I hated that thing. Lol. It was a 3 spd on the column and if I accidently snatched 2nd a little hard the backdoors would fly open and my tools and materials would be all over the streets of DC. Lol.
Dad drove them for years when he worked for the Bell phone company, he liked them, likes mine, it has been well preserved, what he dislikes is all the stuff I am doing, because his belief is if the vehicle needed it, Ford would have put it on there, using that same argument, I tell him well vehicles shouldn't evolve, no power steering, brakes, windows, etc. Seems trying to make them easier to drive and dependable is against the rules, he just accepts the wheel chairlift, hand controls and sliding/swivel seat base as necessary.
I've gone through this quite well, I am not satisfied with my gear ratio and open axle carrier, no way to get at it cheap or easy with a swap, even to try to upgrade to the larger bolt pattern so I can swap to the truck disc brake setup.
Uh, you missed my photos obviously, it is ALL offset toward the passenger side, nothing to do with the alignment like that photo is showing.
Well, yes that's the diff is offset towards the passenger side, but I didn't find a depiction of a drive line in that situation. I understand your point but I don't think u-joints care whether the offset is vertical, horizontal or diagonal as long as the crank and pinion shaft axes are parallel and the u-joints don't bend more than X degrees. The question is, what angle is formed by the length of the drive shaft over that much lateral offset? A 6 foot drive shaft and 6" pinion shaft offset means a drive shaft canted 5*. I'm sure that's way too much for long u-joint life.
