Headlight rheostat replacement
Old Jun 6, 2014 | 11:14 PM
Keithfriend's Avatar
Keithfriend
In trying to find out why my instrument lights don't turn on, I have discovered that the spring that acts as a rheostat around the headlight switch is broken. It looks like I'm going to need a new headlight switch assembly. Does anyone know if this is available anywhere?
Thanks.
Keith
Old Jun 6, 2014 | 11:28 PM
HIO Silver's Avatar
HIO Silver
Thanks.
Keith
What are you referring to as 'it'? The switch or the resistor spring?
Old Jun 6, 2014 | 11:34 PM
Keithfriend
It's the resister spring that goes around the switch. The headlights will turn off and on and the inside dome light also works. The only thing that is out are the lights in the instrument cluster.
Old Jun 6, 2014 | 11:46 PM
HIO Silver's Avatar
HIO Silver
Dunno if only the spring is available. I'd prolly head to the JY and pirate one.
I assume it's broke in half? No chance of adjusting the arm to make contact?
Old Jun 6, 2014 | 11:51 PM
Keithfriend
If I can figure out how to remove the switch assembly, I might be able to repair at least part of the spring.
Old Jun 7, 2014 | 12:01 AM
HIO Silver's Avatar
HIO Silver
Reach behind the dash and there is a small button on the switch body that needs to be depressed in order to withdraw the **** and rod. The ya can undo the bezel to remove the switch from the dash.
Old Jun 7, 2014 | 06:35 AM
yetiman38237's Avatar
yetiman38237
If you cant find one in a jy then any parts store should be able to get for you around $25
Old Jun 7, 2014 | 07:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D3ZZ-11654-A (replaced C5DZ-11654-A - C5TZ-11654-A & B & C - C8UZ-11654-A - D1ZZ-11654-A) .. Headlamp Switch Kit (Motorcraft SW-1245-kit) / Available from Ford & auto parts stores.
1965/66 F100/1100 - 1965/70 Falcon - 1966 Mustang - 1966/75 Bronco - 1967/72 F100/750 - 1969/74 Econoline - 1970/71 Maverick/Comet - 1971/72 Mustang.
Despite the 1973 Mustang part number prefix (D3ZZ), this switch does not fit 1973 Mustang.
No internal parts of the switch can be replaced. And IMO, buying a switch at a junkyard is a waste of time, as it may be no better than what you have now.
Old Jun 7, 2014 | 09:11 AM
Alex from GA's Avatar
Alex from GA
Follow Bills advice. The button is on top of the switch.
niko20
Apr 7, 2019 10:53 PM
mred1239
Jan 27, 2011 08:27 PM
mgdemarco
Jul 7, 2009 05:22 PM
Beastmaster
Jan 1, 2006 10:29 PM
