tachometer installation
Old Jul 8, 2003 | 12:23 AM
adidasab03's Avatar
adidasab03
I have a 2000 Ford Ranger V6 4.0L engine. It has the distributerless ignition so it is a little more difficult to install, from my point of view. I would just like to know what color and where the wire would be coming from the PCM to hook up the tach. Also many of the sites and books that i look at the wire is the tan/yellow wire. I searched for it and found it and it is connected to the radio. What do i look for?
Old Jul 8, 2003 | 09:28 AM
Ken00's Avatar
Ken00
Welcome to FTE!!!
It is a tn/yel wire but it should run to the intrument cluster, I'll pull out my wiring diagrams and see if I can give you more details.
Old Jul 9, 2003 | 10:09 PM
adidasab03's Avatar
adidasab03
Thanx for the info about he tan/yel wire. I looked at some wiring diagrams at my local library and found what the other tan/yel wire went to and what its purpose is. But I want to know if there is a way that i could find the tachometer wire without tearing apart my dashboard.
Old Jul 10, 2003 | 08:49 AM
Ken00's Avatar
Ken00
My 2000 Ford manual shows the tn/yl wire coming from pin 48 at the PCM so you might be able to tap into it there.
Old Jul 10, 2003 | 09:11 AM
Rancha9's Avatar
Rancha9
You should have that big wire cluster that runs out of the firewall into the engine compartment. Cut some of the tape off (Careful!) and it'll be hiding in there.
Old Jul 13, 2003 | 11:39 PM
adidasab03's Avatar
adidasab03
Thanx guys, i got my tach hooked up fine but now my only question is that white wire for the lighting. I dont want to tear apart my dash to find the wire. Is there a way that i can tap into it w/o doing any damage..lol
Old Jul 14, 2003 | 08:49 AM
Ken00's Avatar
Ken00
Try pulling the radio out and using the radio light circuit.
Old Jul 16, 2003 | 12:05 AM
adidasab03's Avatar
adidasab03
what color would the light circut wire be.
Old Jul 16, 2003 | 12:16 PM
Ken00's Avatar
Ken00
lb/rd
brandon4
Nov 27, 2016 02:50 PM
highoctane74
2004 - 2008 F150
Oct 7, 2016 12:03 AM
MFSB
Jun 13, 2015 04:40 PM
holdtyte
May 30, 2011 12:16 AM
boeingoing
Feb 9, 2010 02:38 PM
